dont forget a engine driven compressor, thats the route im going asap. i have the compressor just need a mount and tank
I am in the middle of doing a York compressor setup
York pump. Free from a dumpster at a big rig service centre.
New clutch from Ryder 90 shipped
Belt and idler 25 from rock auto parts.
Manifold and various fittings. 25 so far need more
Air tank 3 gallon. Free just need to modify.
3/8 NPR tap to tap the head of the pump $15
So I have spent so far $155 and I expect that I may spend another 50 to 150 depending on how elaborate I get.
A little over $200 for oba air that will pump enough to run air tools and fill up a 37 tire from 10 psi to 30 psi in less than minute is incredible value. Just need to make a bracket though. The brackets you can buy is ridiculous expensive. Better to make your own bracket if you can.
