1 - 12 of 12 Posts
Daystar is now making replacement hood latches for the JK that are made of a firmer material than the rubber, and that they claim will eliminate the dreaded "hood bounce". They are probably a little more expensive than black zip-ties but I think I'll try them anyway. :)
www.daystarweb.com
Read Only
www.daystarweb.com
hey skibum, let us know how it works out for you when you get it...i'm interested in this as well...
I'm interested in knowing what this thing does differently then the stock latches...from all appearances, it looks the same.
I think it's a stronger rubber/poly material, so it will hold your hood down tighter than the stock, relatively flexy, rubbert latches. Curious to hear how these work as well. I have the zip ties right now and they're working well, but I'd like to go with a less hokey solution at some point.
Read Only
Finally installed the Daystar replacement hood latches today. Took less than 15 minutes, but I had to bust the old latch pins off (not a big deal cause the Daystar ones comes w/ new screws and Loctite). It's definitely snugger than the OEM ones. I haven't driven my Jeep on the freeway today so I can't confirm if it fixed the hood flutter, but I'm feeling pretty confident it will because it was pretty hard to re-latch the hood!
Discussion Starter · #8 ·
Keep us posted. I removed my hood spring and it solved all but the worst of the problem, but if these take care of it all, then I'm in line for a set.
I can confirm that the daystar replacements fixed by hood flutter :bounce:
Exactly the point I used to preach on the other site. The primary system for holding down the hood was not capable due to the insufficiant durometer value of the "rubber bands". That's why I took the route I did. Taking off the spring and bolstering up the seal were work arounds for the effect, not the cause. Glad they're working out for you!!
I never had hood flutter....could it be the removal of the air dam helped prevent it?
1 - 12 of 12 Posts
