1 - 8 of 8 Posts
New never used AEV ProCal. Bought it for a friend's jeep that I helped her lift, but sold before I ever got around to reprograming.
ProCal Module Functions:
•Large tire recalibration (Restores the vehicle's speedometer/odometer accuracy following the installation of larger-than-stock tires)
•Axle gear ratio recalibration (Resets automatic transmission shift points to maximize the benefits of an axle gear ratio change)
•Tire Pressure Monitoring System recalibration
Note: Lowering a vehicle's tire pressure below that specified by the vehicle/tire manufacturer may create unsafe handling characteristics. AEV assumes no responsibility for a vehicle's handling characteristics or the safety of the vehicle's occupants.
•Daytime running lamp activation/deactivation, and lamp location selection
•One-touch turn signal activation/deactivation
•Engine idle speed options (Improves winch performance and battery charging capabilities by temporarily increasing engine idle RPM)
•Steering wheel centering (Provides for spot-on steering alignment)
•Clears Engine Diagnostic Codes
Retail is $149+ tax/shipping. SOLD.
so this is indeed sold?
1 - 8 of 8 Posts
