http://aeroforcetech.com/index.html
I check this website once every couple of months, looks like these folks have finally included the JK. This is a great alternative to the ScanGauge II.
Among the regular stuff are some that are quite unique:
Trans temp
TCC slip
Engine load%
ESP parameters
steering angle
yaw
lateral g
logitudinal g
I poked around a bit more and supposedly it will completely disable the ESP.
It also has two analog inputs that can be configured to whatever you like.
There are also several sensors they sell that will work with the analog inputs:
Oil pressure
Fuel pressure
Boost sensor
Vacuum Sensor
Air temp
Fluid temp
You can also get dual guages that piggyback.
Not bad for a base price of 239.00. Dual setup is 399.
Trans temp
TCC slip
Engine load%
ESP parameters
steering angle
yaw
lateral g
logitudinal g
Oil pressure
Fuel pressure
Boost sensor
Vacuum Sensor
Air temp
Fluid temp
