1 - 12 of 12 Posts
Hey all-
So my black jeep came with the chrome mopar fuel door cover and i really cant stand it. I was looking at buying a black one and replacing, but due to cost, i am now thinking about just painting mine black.
Any advice? I am not a big "handy man" and have no experience painting something like metal/chrome.
I want to paint it black, either matching the black color of the jeep or the black color of the fenders/hard top. Any thoughts on what spray paint i should use that will last a long time and have the "shade" of black i am looking for? Someone had mentioned spray on bedliner but i am not sure "how black" the color is.
Should i use self etching primer? If not, what method of prep should i use to make sure the paint will stick and not flake off?
Thanks in advance for your help!! I am getting better at this stuff...slowly but surely :bounce:
best bet would be to sand the chrome finish off of the cover until its a little rough in texture, use simple green to clean of and dust/particles. spray it with primer. sand. simple green. primer again. sand. simple green. then use plastidip. I think it's made by duplicolor but im not sure. A quick google search and you would find it. Use as many coats as desired. Add's somewhat of a rubbery finish but from what I've heard doesn't flake like a spray paint might. hope this helps.
Buying a new one would be ideal. But, considering they are quite expensive, sanding, priming, and painting will be one of your options.
This is what I did to my Jeep's black fuel door:
I removed the screws, taped the whole door with painter's tape, and then I removed the tape from the letters. I then primed and spray painted (PR4 colour code - Flame Red) the door. It didn't come out too badly.
Discussion Starter · #5 ·
Ya i do appreciate the input. Sounds like a bit of a task. After buying the supplies and taking the time to do it, it may be worth it to just buy one lol. Does sounds doable though..
JKO Dickhead
C'mon....scuff it up...hit it with a little primer then hit it with some satin black..matches the Jeep black plastic fine !! $5.00 and about twenty minutes !
JKO Dickhead
Self etching is best for bare metals...and something that you want a durable base coat... gas door probably isnt taking much abuse... reg primer will be fine !
i dont even have a gas door... are they metal or plastic ? lol
1 - 12 of 12 Posts
