1 - 20 of 47 Posts
I know this as been asked before, but did anyone ever find the part # for the rear axle shaft ABS tone rings?
Thanks
52125003AB is the part number to the rear wheel speed sensor.
It's not the sensor we're looking for, but the ring that rides on the axle itself by the bearing/seal that the sensor "reads" for the information. As far as we've been able to find, we've been told it only come with a new stock axle shaft.
Oh ok...these might work; they're the bearing retaining rings - 83503077 - and the only "rings" on the axle itself.
ColinW thanks for your efforts on this though.
Yeah, I'm assuming it's that gear cut thing in the picture with what looks like a sensor mounted radially to the side of it...don't really know what to tell you...sorry! You could probably just call up a Jeep parts department and ask them to find it in their computer system if you haven't already.
Discussion Starter · #9 ·
Yup, that's it.
Tried that, and they couldn't find it.
irate4x4 dot com
maybe try to call Dana/Spicer
i've done some checking and i can't find it as a single part either. it's probably another one of those parts that chrysler decided not to sell individually so that you would have to fork out the cash for an entire axle.
Discussion Starter · #13 ·
Yup, and I don't think there is any aftermarket ones available yet.
What about you people carrying spare axle shafts, are you carrying shafts without tone rings?
Discussion Starter · #15 ·
Are you replacing your rear axle shafts Phil?
Yup, I actually meant to do it months ago, but have not gotten around to it.
Silly question, but are the rings removable from the old shafts?
You can remove them easy enough, just pull the collar and bearings off, but I was hoping to leave the shafts intact with bearings and tone rings in place, so they would be ready to use spares.
My friend works for the dealer and I had him look it up, they are only available as part of the axle shaft assembly.
How about some of the companies that offer aftermarket axles??
What about the machine shop option? If they are removable couldn't you have them duplicated? Possibly this would be cost prohibitive. I donno...
Probably cost as much as a new axle. I was thinking it'd be real easy to get some chrome moly rear shafts, put on new bearings, seals and tone rings and do a quick R&R on the rears as I don't have a hydraulic press or alternative means of transport. That would have also provided me with instant spare axles. This'll probably end up being the job I have to pay someone else to do.
Here you go... From both the 2007 and 2008 parts catalogs, for either Dana axle:
#3 RING, Axle Shaft, Part # 83503077, Qty 2
And your dealer could not find this or is it not the right part???
1 - 20 of 47 Posts
