Yesterday a stick wedged up on the drivers' side of my t-case. It broke the metal breather vent right off the t-case (that was the hose Evan saw dangling loose), the t-case position sensor, and the plastic bushing on the t-case shift cable.
My plan is to drop the trans crossmember a couple inches, and try to replace the breather vent without removing the t-case or splitting it open. Then the sensor. The bushing clip I did this morning.
Does anyone know if it is possible to do replace that metal fitting without removing the t-case?
Pics of dubious value
This is the broken tube on a picture of the t-case
This is the sensor harness that clips to the t-case position sensor. It is broken, at least the retaining clip is, (4x4 indicator lights and no flashing sway bar light make me think it's ok) but maybe some small zap straps and some epoxy will suffice.
If anyone has advice, I would appreciate your feedback.
Darren
Darren
