1 - 11 of 11 Posts
I'm about to make the jump from stock wheels/tires to aftermarket. Running a 2016 JKU all stock suspension. It's a daily driver for my 8-5 and my chariot in the rocky mountains on the weekend.
I want to run 285/70r17 Duratracs on 17"x8.5" wheels with 5.2" backspacing and I want to avoid wheel spacers. My reading has told me that I will not rub the suspension, sway bar, etc - however, apparently I will have the clearance I need by a very small margin with 5.2" backspacing and I need certainty that this wont be problematic before i start shelling out the $.
Is anyone currently running this set up? Thoughts? Advise? Much appreciated!
that tire size comes out to just under 33" I think you will be totally fine with 33" tires and 5.2" backspacing.
although personally i'd recommend going with a 4.5" backspaced wheel as it will allow you to install taller tires later if you want. everyone is happy with their tire choice for a few months, but it's pretty common for people to upsize tires later...
Yes - I like the way my stock wheels look so I was leaning towards Quadratec Moabs (apparently I can't post a link because I'm a new member...?)
Either way, it's 17x8.5 with 5.2 BS
No I run aev Salta with those specs and run Toyo 35/12.5-17 and no rubbing I like 5.2" bs.l of of guys running 37s on aev rims.
@Jadmt - are you running stock suspension without a lift? Any wheel spacers? Ideally I want to keep everything OEM for now (besides the wheels and tires, of course)
Discussion Starter #10
No spacers but a 3" lift. You won't be running with stock suspension with 35's without rubbing.
Agreed - I'm trying to run 285/70r17 duratracs though (33"), it's a commuter so I need the MPG and I don't want to regear.
Research tells me that if I run 285/70r17 with 5.2" backspacing then I can keep everything else stock without rubbing the internal components or the OEM fenders. Some have told me this theory is right, and some have told me it's wrong...
Discussion Starter #11
Took it to the local 4x4 shop. The experts say I'm clear if I have 4.75 backspacing or less. Just ordered the Mamba MR1Xs. Thanks to all for the help.
1 - 11 of 11 Posts
