5.13s, 1,000lb trailer, 6sp... 35"s or bigger?
The wife and I want to build our JKX into an overland expedition capable rig that can haul our family, gear and up to a weeks worth of supplies with an off road trailer... or SeaDoo / ATVs on shorter trips.
My family weighs 550lbs and the loaded trailer should be around 1,000LBs.
The '07 is a 6speed hard top (will be insulated) with a winch bumper up front, recovery gear, hi lift, fiberglass handled axe/shovel, large fire extinguisher, back seat, with C02, side and belly armor to be installed soon. I also plan to run a TJ tank mounted in the rear as an auxiliary (+18gal). My family weighs about 550lbs with the dog. I will be running field serviceable wheels so I don't need a carrier, just spare rubber.
The JK will be seeing DD use with a 4 mile round trip on week days.
The plan was for 37"s so I already have a sleeved/gusseted/locked D30 with 5.13's awaiting install. I am thinking that even in the true 35"-36" range the 5.13s might be perfect for towing that weight.
Please share your thoughts about what tire size I could spin comfortably with 5.13s and a trailer, as well as pros/cons of a WD hitch at this level.
