1 - 2 of 2 Posts
So ive had this 430n RHB stereo in my 15 jku for about 2 yrs now. I got it from another fellow jeeper, and it has always worked great. I installed a backup camera on it almost imediatley and never had any issues. just recently I added a pac bci-ch21 to control the nav while driving and to access the back up camera in any gear and it has been working flawlessly. just about a week ago my video screen went black while in reverse and it wont pick up the video signal. the pac module is working just fine, it still switches from nav to video on command but the screen is black. I have swapped out the rca cable leading from the camera thinking that was the culprit but it does the same thing. I externally wired the rca to my traildash 2 screen to eliminate the camera and it is working as it is supposed to. so I decided to take out the radio( I figured the rca cable came loose behind the deck) but everything is connected as it should be. I tried eliminating the pac module and ran the rca directly to the radio but it does the same thing. I even swapped harnesses out thinking the pac harness was defective but nothing happens. I constantly get a black screen when in reverse or when I trigger the camera through the pac. Do the video cards go bad on the 430n's? do the 430n's have issues with just the video feed? do I need a new radio? mind you all the other features work fabulously and I don't want to loose the ability to use the steering wheel controls or even loose the function of the microphone or the usb port in the console. Just wondering what others have experienced and how to fix this issue.
****I have searched, and I am still searching.
TIA
1 - 2 of 2 Posts
