1 - 1 of 1 Posts
$245
Used once for existing Jeep, taken out and removed to stock so can used with another Jeep, nothing wrong with it, brand new.
Tuning levels:
93 Performance – Max Gains include an additional 30 HP and 30 lb-ft TQ!
91 Performance
87 Performance
Tow
Crawl
SAVE (Mileage tune)
Custom Options:
Corrects speedometer for tires between 22.5″ – 44.25″
Corrects auto trans shifting when upgrading gears (transfer case and rear axle) between 2.00 – 10.00
4-Hi front & rear axle lock options (Rubicon Only)
Adjustable speed limiter options
Electric fan adjustability for improved cooling
Real time idle up feature
Tire pressure monitoring adjustability (on and off-road)
One-touch lane change options
DTC reading and clearing
Advanced data acquisition
Internet updateable
Pedal response adjustments
ESP stability optimization
Daytime running light options
Radio delay
Headlamp delay
Door lock horn chirp and exterior light flash options with keyless entry
Hard part compatibility:
Cat-back exhaust systems
Cold air intake and/or hi-flow air filter
The Flashpaq for Jeep is the best-selling handheld tuner worldwide. Its success comes from quality, innovative Jeep specific calibrations, and seat of the pants performance results. Flashpaq delivers the most power to-the-wheels while eliminating common problems found in the other products. Today's Flashpaq contains a lengthy features list including multiple power levels and a variety of user-adjustable options. The first time you get behind the wheel with the Superchips Flashpaq you will notice improved throttle response, high-end drivability and outstanding power gains.
The Superchips Flashpaq for Jeep now offers tuning for ’07-’14 coverage. While the horsepower and torque gains from the specifically tuned Superchips calibration are worth the price of admission by gaining up to 24hp & up to 28ft pounds of torque, the sophisticated transmission tuning makes your Jeep drive like a dream. Cut up to a second off of ¼ mile times with the performance program. Ease the pain at the pump by using our exclusive 87 octane tune. In summary, get it all with Superchips. Superchips also offers CARB tuning that has been tested and verified for use in the state of California as well as any state or country currently applying CARB emissions standards.
99-01 Jeep Cherokee (XJ)
06-09 Jeep Commander (XK)
99-04 Jeep Grand Cherokee (WJ)
05-08 Jeep Grand Cherokee (WK)
98-06 Jeep Wrangler (TJ)
07-14 Jeep Wrangler 2-Door (JK)
04-06 Jeep Wrangler Unlimited (TJ)
07-14 Jeep Wrangler Unlimited 4-Door (JK)
1 - 1 of 1 Posts
