1 - 16 of 16 Posts
Has anyone out in Jeepland done an engine swap with a ford 302? I know this may sound crazy but to me it works. I want to buy a Boss 302 from Ford along with a Painless wiring kit for like a '72 Bronco and wire the Jeep that way. I know it will mean all new gauges but the simplicity of not having to get the Jeep to speak Ford would make it worth it. I am old school, really old school, and I think it would work very well. My biggest question is the installation of the motor in the JK. Any thoughts?
Random Dude
Wrong 302 . . .
A wheeling Jeep is not an appropriate vehicle for an old-school Boss 302 (unless you're building it for sand drags, mud drags, or similar). Waste of great engine and a potentially great vehicle, IMHO.
Why I feel I'm not completely talking out my ass:
I've stuffed a 351C 4V (same heads as a Boss 302) into a '65 Mustang and it made jack shit for power below 2500 RPM (above 2500, gobs of torque everywhere :devil: :laughing: ).
The intake ports that you can almost drop a golf ball through and the 2.19" intake valves are made to excel at high RPM at the expense of low-RPM performance.
The old Boss 302 is really a race / track engine, and it kinda' sucks at around-town daily driving. That engine begs to be beaten like a rented mule, and it will reward you when you do, but it is frustratingly "meh" when it's not in its happy place.
Do what you want but, unless you're building a high-RPM race car, that's a stupid engine swap candidate.
I'd love a 302, but I'd do a 5.0L from an early '90s fox body, probably punched out to 331 or 347 cubes and topped with aluminum heads. To me, that would be a very rewarding, compact, lightweight jar of torque for a wheelin' Jeep.
EDIT: if you don't want fuel injection (I get it, my F250 w/428CJ is carbureted) I'd build an aluminum-head 331 or 347 carbureted, but with WINDSOR heads.
Also, if you haven't wheeled with a carburetor, it can suck . . .
Either way, please post photos of your swap! :beer: One way or another, it will be interesting :laughing:
(photo snagged via google image search attached here to illustrate ginormous intake ports)
you can go piss up a rope
The 302 (or a bored rebuilt 306) is about as far as I would take it for an offroad application. Not sure why you'd want a high rev 331 / 347 to putter over rocks.
Also, I don't get everyone's obsession with putting Cleveland heads on a Windsor block, but there's better options with mildly modified Windsor heads, or better yet 3rd party aluminum heads. I spent the majority of the late 90's / early 2000's trying to squeeze power out of a 302, then went to a 351 until Mr. Smog started measuring deck height, then back. At the time, oiling was still an issue with 347s. Working on fox bodies is a lot of fun, but my observation was if you wanted to pass smog and win races, the Windsor platform was a waste of time.
I know there will always be the guy that wants to wedge in something "different" but let's be real here.. if you are on a forum asking how to make a carbed 302 "speak Jeep", you aren't going to be swapping anything.
EDIT: Somehow I didn't see anything ExWrench said in between those photos. So I should have just x2'd him : )
Speaking Jeep isn't the issue. Rewiring it to a simple format would eliminate the need for an ECM. A simple electronic ignition and a Holly EFI would be all the computer/ high tech modern control it would have. My concern is about any sort of kit available to install it. I see tons of info on
Chevy and Dodge engines but not a lot on Ford. Doing a custom job is an option but I would rather have some sort of kit that someone has made to eliminate all the engineering problems that would arise.
As for wheeling with a carb, been there, done that. I am not some young punk with wild ideas. If you set the carb up right, they do just fine in the hills.
Report to KOWBOY's thread. He's ripped out all of the factory crap in exchange for just the basics + all at high altitude. If you live in an area where you can do that without your nanny-state telling you no, more power to you.
I get what you want to do, I just don't get why you want to use the wrong block. Why do you want a Boss 302 vs. 302HO build? I know the differences, but do you? A 302HO designed for low-end grunt? That might be a fun challenge.
Just curious, why not an LS swap?
There is no issue with emissions so I don't have that problem. As for boss vs normal, and I do know the difference, the boss is probably overkill unless I stuck to mud or sand dunes. Years ago I built what Hot Rod defined as a "bogus boss". I stuffed it in my 69 F-100 with a close ratio top-loader and pulled low 12's. This is just an idea for the moment. I still want to know if there is a sb-ford kit being made tho. As for the chevy motor, I actually have one sitting here. I picked up an older Suburban with a killer 5.7 in it for this very purpose. Its got Edlebrock heads on it 1.7 rockers etc...... but it would be vanilla. Everyone does Chevy or, if they are rich, they stuff a hemi into their Jeep. Next to Jeep, Ford is my choice. Anyway, thanks for your opinion. Time will tell what will happen!
I guess I am completely lost here. You want to stick a boss 302 motor in a JK. You didn't specify what year JK, but then I guess it does not matter.
I have been on the JK forums since the JK came out. I have never seen or even heard of anyone doing a kit to swap any kind of a Ford motor into a JK, let alone a boss 302 motor. The market size for such a swap would be limited to you I am afraid.
And if you want to strip out all the current gen electronics, (no more cruise control, HVAC, radio, ABS, etc, etc) what exactly do you need in a KIT?? The motor mounts and radiator???? Any of the LS or hemi swap radiators would work and well shit, just fab the damn motor mounts.
If you want such a thing, why not just buy a CJ7 and do it. That is essentially where you will end up anyway.
Where's bluewave, he can help you do this swap for under 250k. He might throw in the front leaf springs for freeeeee.
Random Dude
Now, be fair - that build took the roll cage to the next level . . . because it was too low, & gonna smack the driver in the head :laughing:
OP - give Novak and/or Advance Adapters a call as they have probably at least given a “kit” thought and should be able to recommend things less easy to fab like exhaust manifolds/headers, cooling system, etc.
Those folks already have Ford related stuff up to the TJ and I imagine with the JK’s age getting up there they are looking into it for non-integrated installs.
You beat me to it. I was just going to say the bar was set so low, someone tripped over it. hahah.
OP-did you do/start the swap? I went through the same dilemma, I really wanted to do the 302 and the only reason I didn't was because I found a screaming deal on a 4.8 Chevy/trans/tc. This project wasn't a jk but an old commando, but if I had the 302 I would have used that and probably a sniper kit or even the efi kit the Howell is making for the ford...
Sent from my iPhone using Tapatalk Pro
1 - 16 of 16 Posts
