go 3.73 tow package. won't regret it.I have a 2013 JKU with 35s and am running 3.73 and have plenty of power. You should be fine!
I say do it, 3.73 is fine stock. You can always re-gear it later. If you lift it (even a BB) you'll eventually want larger tires. Stock tires are too small/skinny for even a small lift, IMO.Looking at a 13 2dr, JK with a auto trans. 4:10s are hard to find, is it worth it to go for 3:73s, I don't plan on larger tires, but BB lift of 1 3/4 inch?
Except for 2007, 4:10's are Rubicon only. Used to be 4:10's were the only ratio for the Rubicon, but with the Pentastar they also use 3:73 in the Rubi with 4:10 as an option.Is 4.10 even available outside the Rubicon? When I first started shopping and going through the build scenarios, the Sport options are 3.21 and 3.73.
