So here I go , three days ago I went to start my car and as I was driving my dash messages started to flicker // I stoped the vehicle turned the key back in and won’t start or crank // my esc light ,electrical fault ligjt security light and engine light on the engine light and battery light occasionally flicker // so I towed it to mg work /: I load tested the battery’s the battery failed at five volts lol //installed new battery tried to start still hot oil message and chime my symptoms are as follows
Key fobs won’t unlock and lock the doors
No crank no start
Security light above the gauge stays on solid red
this vehicle has 75000km
After removing tipm cover I swapped k5 relay with the bLower relay nothing I checked the relays with my relay tester all good // 20 amp fuse is good // all fuses good relays working //
things I noticed there are times I have zero power in thevehicle if I open and close my door it all comes back up
what I did so far
Replace battery
Checked fuses and relays
Inspect harness
Unplugged tcm re connected
Hard reset all night
Unplug tipm and re connect after inspecting performed relearn
Checked skim module or wcm pulled fuse to reset
Removed battery box and battery checked harness connectors and wiring checked all grounds in that area for signs of corrosion or damage nothing iam at a loss here part
Lights all work ok
Wipers work good
Windows go up and down
Just the doors won’t unlock or lock anymore with fob
toms of loss of communication faults in bcm
my question this seems like a bad wcm module on my ignition switch area can this cause no communication with bcm and loss of power like this iam torn between tipm and wcm
anyone experience this I love my jeep and it’s been three days so far
No crank no start
what I did so far
Replace battery
Inspect harness
Lights all work ok
Wipers work good
