1 - 1 of 1 Posts
Putting this here as well as the electrical tread. Any help is appreciated.
My 2015 Rubicon fan does not come on. It it throwing the P0480 and P0693 codes. I have checked the power/ground to the plug, made sure they are connected tightly at the battery and body. All fuses are good. I have reset codes multiple times and it doesn't disappear. For a while I could reset the codes and it would be good for a while. Now it doesn't go away at all.
Are there any relays I can check/replace/swap to see if that is the problem.
Also read it could be the temp sensor but would like to know if there are any relays I can check first.
1 - 1 of 1 Posts
