hey everyone, my 430n quit on me, well the gps quit, so I bought a kenwood dmx7706s to replace it, now my problem is wiring the thing in, what wiring harness do I need, I've replaced radios before but none with the canbus.
any help will be appreciated, also how do I access the onboard amp and subwoofer?
ok, so I've found some trim panels online, all come from the states, I'm in Canada, found one for 14$ but 35$ shipping, gonna have to wait until Monday to look at my local Jeep dealer, they are closed on weekends :frown2:
hopefully it won't cost an arm and a leg for 2 little plastic pieces
Build the system with the radio you bought on Crutchfield. That will help you determine what you need. Found their prices for harnesses and other things in line with amazon and other retailers. That’s the route I went with the Alpine ILX-107 I got.
I installed the same head unit last fall. I love it and have one in my Tahoe as well. However the fit in the JK is not good. What dash kit did you use? I have tried Metra's and another brand. Neither fits well. Ther are gaps all around the screen. I feel like the kits I got are made for the 2007-2011 dash, but they all say 2007-2018. Has anyone else run into this problem?
Yes
But the dash kits I have found are listed for 2007-2018...I have not found a dash kit for 2012-2018...do you happen to know the PN of the one you used?
Make sure to use Locktite on the side screws holding the dash kit onto the radio. Had to open up my dash recently tighten up.
Also, I had to trim the metal OEM bracket so the head unit would angle up a bit more. I also used some washers behind the lower screw holes of the dash kit to help make flush.
Yep that’s exactly what I’m using now.
I think what you were saying about modifying the factory mount is what I’m going to have to do. Can you give more details about what you had to do?
I really appreciate the information
It’s not apart right now. It’s been together for about 7 months but it bothers me that is doesn’t look right. It may be a few weeks before I pull it apart, it’s going in for a regear Tuesday and then the lift is going on the following week. I’ll send a picture when I get it apart...just may be a little while.
Thank you again for your help!
JDE22,
Did you install the parking brake bypass switch? If did not, you definitely should. Don’t have to double set the parking brake and you can access the settings on the roll.
Yep I used one of those. I knew from installing this stereo in my Tahoe that I needed one. I can’t imagine having to stop and set the p brake every time I want to use the apps
Agree. I was perplexed as well. Had to buy mine off eBay since it was no longer being sold.
Sent from my iPhone using Tapatalk Pro
Related Threads
JKOwners Forum
2M posts
62.8K members
Since 2007
A forum community dedicated to Jeep Wrangler JK owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, reviews, engine swaps, troubleshooting, suspension, and more!
