1 - 15 of 15 Posts
Good day to all,
So I have had my 2013 rubicon for a few months now. It was only 4 weeks between the day i placed the order with the dealer and the delivery. Beautiful rugged brown on dark saddle leather, fully equipped. However, apart from the kargo master roof rack and basket, it is still stock. I have an issue with that.
Since I am a bit anal about what parts I put on my cars, I have done some extensive research and am about to order a whole heap of parts for this puppy.
I want you guys opinions on some or all of the goodies i am planning on installing...
So,
I am only getting a small lift in this time, and i have narrowed it down to the Rough Country 2.5" spacer lift with track bar. Cheap and it has "ok" reviews.
old man emu steering stabilizer.
Spidertrax spacers and Dick cepek FC-II 35"
I already have an original jeep front bumper from the 2013 moab edition. I got it for next to nothing and it is sitting in the garage at the moment, feeling lonely.
warn M8000 winch with synthetic.
Magnaflow catback (or mbrp, not sure yet)
Superchips flashpack (i guess Chrysler gave in since it is now available for the pentastar...)
Synergy suspension skid plates.
All input, and I mean ALL input is welcome.
Discussion Starter #2
Really guys? No feedback? Usually, everyone has an opinions on forums...
They're all doped up on leftover turkey and pie.
Some might say that for a jku, that you might need a bit more powerful winch, but whatever on that. That's a good quality winch for sure.
I think you could do better than the DC FC II's... like maybe an MTR, but that's your call. I ran em on a TJ and they were okay, but there are definitely some better ones out there.
Not sure why the wheel spacers. If they're for clearance due to factory wheels/ back-spacing then I guess. Otherwise I wouldn't run em unless you have to.
Everything else sounds good/ okay.
I wouldn't waste $80+ on a SS.
The stock one works fine and there's no need to spend hundreds of dollars on one.
Buy a CB instead.
and everything else Stub said.
Didn't realize an OME stab was upwards of $80.
Definitely money spent better elsewhere.
I haven't even run a stabilizer for the last 3+ years.
Thx for the input guys. I have had to put a SS on my old TJ just because, well... because. Then I had one on my altitude because it came with the lift kit. I guess I will see if it is needed. and yes, it is about 80$...
I had the Dick Cepek on my altitude and loved them. but i only bought them because it was the best deal between the MTR, the Falken wild peaks, and the Mickey Baja ATZ.
And yes, the wheel spacers are required because i am keeping the stock wheels. I know the new rubi wheels get a lot of hating right now, but I kinda like them...
Good call on the RC BB, mine works great. If you're looking for a good A/T tire check out the Duratracs.
You probably would be better off with a 10K winch, as mentioned.
thx. I have had duratracs before and I loved them. I only wanted to try something different this time...
Bite the bullet, spend the money, and get a spring lift with control arms. I went with the RockKrawler 2.5 max travel and am very pleased. The difference in handling between mine and my buddy's Jeep that has a cheap kit is very noticeable.
Discussion Starter #10
I agree but there is a 1000$ difference between both options, as the BB is less than 200$...
Sir
If you have any questions on our products, please let us know. We are here to help. A lot of dealers and wholesalers will be having great deals for the up coming holiday season. That may help you out…
RK
As long as you understand the limitations of a budget boost then go for it. A spacer lift is a spacer lift and RC at like $170 is a great deal. Make sure it comes with brake line brackets. I would scrap the steering stabilizer, your Jeep is brand new, stock one is fine.
I would splurge on some good shocks (not RC) like Bilstein 5100, Fox, Rancho RS9000 or whatever. Get a bigger winch (Recon 10,500 can be had for under $500) and go with a better tire.
-Dan
Discussion Starter #13
-Dan[/QUOTE]
Thx. I had the RC spacer lift in my crosshairs because of the shocks issue. I am planning on running the stock Rubi ones for now and maybe invest in some better ones later. I Was not overly mpressed with the RC shocks last time.
What tire would you recommend? I see snow every once in a while here...
You can use the shock extension brackets. I am an overkill kind of person though.
Falken Wildpeak and Goodyear Duratracs (Kelly Safari TSR, same as Duratrac) are rated for snow. With the other 2 being more aggressive. Falkens are good on wet, dry, snow and rocks but are questionable in mud and are heavy.
-Dan
Discussion Starter #15
I am going to give the Falken wild Peak or rocky mountain a try. I'm getting a pretty good deal at DTD for a set of 5. First Off road Falken product I have ever purchased.
1 - 15 of 15 Posts
