1 - 1 of 1 Posts
It's leaking from that $%! transmission cooler line fitting at the front driver's side again. This'll be like the fourth time I've replaced that SOB, including replacing the entire hardline last time.
The problem is that it is a hardline, and as the engine/transmission combo vibrates back and forth, it wears against the o-rings that are the only thing keeping the transmission oil in. This is nuts. Does anybody have a solution to this other than changing that fitting yet again?
1 - 1 of 1 Posts
