One more trip planed end of the month to the 70th then it's getting sold.
Sold home and moving so one less vehicle to deal with.
2011 Jeep Wrangler Unlimited Rubicon. Currant miles 47561
Approx 7000 on complete build.
Wheels and tires all 5 have 1200 miles +-
All oils and filters just changed.
2012 tapshift shifter
Cruise control
Auto AC
Pentastar fan
Big Motech radiator
Custom Aluminum over flow tank
Mocan custom LS swap kit by John Schumacher Overland Performance
Fully loaded Rubicon with every option other than leather, hard top, 730N Media Center, power everything.
AEV vented Hood
2012 Lc9 motor and 6L80e trans had 840 miles on them when bought and modded.
Motor has Comp can, LS7 lifters, valve springs etc.
DOD deleted, VVT Comp cam with phase limiter.
Custom tuned engine and trans.
6l80 4x4 Trans
Both out of a 2012 Tahoe with 840 miles.
R2C Performance Products custom air filter.
Approx 420HP/tq at crank.
Engine custom tuned by Real Performance Speed in Sparks NV
Runs on Reg or Premium
Trans custom tuned by Zero Gravity Mesa AZ
Atlas 2sp 3.8 HD 300m outputs Flat tow capable with cable shifters. 1570 miles since install.
Jeep towing harness installed.
Custom built XD60 with f450 brakes, Pro Steers, Dynalocks, 5.38's and ARB's
Rear PR80 5.38s arb's
All Vented to high mounted billet roll over filtered valves
5ea new 40" Nitto Trail Grapplers on KMC Grenade wheels Beadlocks.
J-flatter's air down valves.
Suspension is all custom:
7075 Aluminum long arm 3 link front.
SAW 14" 2.5" C/O's, SAW 14" 3 tube Bypass shocks. TG Limit straps.
RK Pro Joints
Rear Triangulated cromo uppers with Heims.
Triangulated Lowers cromo fabbed heat treated trailing arms with Heims and Delrin bushings..Frame notched to allow rear C/O and bypass shocks. Built by Phil [email protected] Liberty Mountain Fab
Rear 12" SAW 2.5" C/O's and SAW 14" 3 tube Bypass shocks.
2" rear King Bump stops.
15" front travel 18" rear unstrapped.
Shocks modded and custom tuned by Phil [email protected] Liberty Mountain Fab.
All brackets 1/4", most fab parts A100 3/16 steel or Chromoly.
TK1 Racing KOH front, rear Currie 1" sway bar. Installed by Phil [email protected] Liberty Mountain Fab
PSC steering box, ram, Rez and cooler.
7075 custom tie rod, Currie HD drag link, RK track bar.
Genright 20 gal Aluminum tank and steel skid plate.
Custom 3/16 plate full skid plates by Phil [email protected] Liberty Mountain Fab.
Expedition One front bumper with Warn 9.5 CTIS winch and Factor 55 Winch Lock bolt and Shackle mount.
Poison Spyder Customs rear bumper (brawler series with swing out rear tire carrier) Custom built tire mount holds a 40.
Poison Spyder Interior Trail Cage
Hard Rock harness bar
Poison Spyder Brawler Rockers
Rigid Dual Rear back up lights
Boom mat sound insulator in Hard top, inside top painted black.
100% Complete interior is Dynomat covered.
Adams frt 1350 cv , rear is a custom by B&W drive-line 1350 cv/1410
Custom stacked plate trans cooler all ran with SS and AN fittings
Carrichs ipad or android holder
Designs 67 carbon fiber mounting system for Ham Kenwood TM-V71A head and Traildash. Ham TM-V71A body and Anytone CB mounted overhead.
Crow 4 point harness plus stock JK belts
ARB compressor mounted behind passenger tail light
Magnaflow 2.5" 400 cfm flow Cats. all 2.5" 304SS with 2ea BORLA mufflers tied to 3" back to a passenger side 4" Magnaflow muffler. All wrapped with Heatsheild muffler wrap. Underbody covered with Heatsheild 2000* stick on.
Bushwacker flat flares
Huskyliner floor mats and cargo area mat
Mopar fuel door and door sill protectors
2ea Full rear Springtail Solutions Molle storage panels with compartments , plus Molle bags.
A custom Aluminum Flat floor from rear to front seats with storage under area where 2nd row seat foot well is.
Sealed 7 Hid Headlights.
2ea Hids with Amber covers
1ea 20" dual pattern LED
2ea front 10w LED rock lights.
Spod with lighted switches.
2ea Hawker Odyssey batteries with Painless dual battery system
All ran with 1AWG copper fine wire welding cable and Military spec connectors.
All glass quartz tinted dark.
Engine, drive-train, all suspension has approx 7000 miles since built.
Comes with all tuning files plus HP tuners. Software and hardware.
Much More not listed.............
