1 - 20 of 29 Posts
RIPP Superchargers is proud to announce the 2011 Jeep Wrangler Supercharger kit. Producing 230 rear wheel HP and 240ft/lbs of rear wheel torque. Complete systems are fully calibrated, plug and play ready, featuring the self contained V-3 Si-Trim centrifugal supercharger with air-to-air front mounted intercooler. The complete system will boost your stock 2011 Jeep form 140 rear wheel hp to 230HP* and 240lb/ft* torque with 7-8 PSI from the V-3 supercharger at the factory redline.
2011 Wrangler RIPP Supercharger Kit Dyno Test 220hp - YouTube
Complete System Included:
  • Vortech V-3 Si-trim compressor with 3.60' drive pulley
  • Peak Manifold boost pressure: 7-8 psig @ redline on stock engine
  • RIPP Pre-Programmed Plug & Play Electronics with a safe, custom calibration for 91-octane fuel
  • Fuel system upgrade includes plug and play fuel injectors
  • Air inlet assembly includes: High-flow roto-molded ducting and high flow air filter
  • Silicone couplers and reducers with stainless steel clamps
  • RIPP PCV and breather hose provisions for both automatic and manual transmission applications
  • Easy to follow instructions
  • Hardware One Year warranty
Discharge components include:
  • Welded air/air charge cooler
  • Mandrel bent aluminum charge tubes for high flow and minimal weight
  • Stainless steel clamps
  • Silicone couplers
  • Quiet Race Bypass Valve Installation time is rated at 8 hours
Vendor
Looking good guys! I like that ad. Very nice....
Very nice! Do you guys have a custom tune to run this kit on the 2011 jk? Could you also run the headers with this kit on a 2011?
The '11's use a different setup in regards to the tuning. And yes, they have the headers avalible for the 2011's.
-Jason
Keeping my fingers crossed...will be able to purchase in February....great ad by the way also!!! Ripp Rocks!
Discussion Starter · #16 ·
One big 2011 happy family... the more data the better... Look forward to delivering one and starting another... That would be 5 separate supercharged 2011 JK's on the dyno.
With borrongo - we will Dyno all three stages of mods..
RIPPTECH
1 - 20 of 29 Posts
