Can anyone shed some light on the wiring connectors behind my factory stereo, there are 2 connectors that came out of the stereo but none of the wire colors match any schematics i have seen. I have the 2010 Jeep JK Sahara with infinity system. There were 2 antenna plugs 1 I guess is the antenna and the other for the satellite/Uconnect?? The big grey 22 pin plug with yellow/red, black, grey/orange, grey/blue, green, green/orange, white/orange, white/grey as seen in the pic. Smaller grey 10 pin plug with green/yellow, green/light blue, green/light blue, grey and grey as seen in pic. Also there is a third plug that is black 4 pin plug with 3 wires white/green, black and pink that doesn't connect to anything it just sits there taped up with pvc? Any info or help will be appreciated.
hello stranger .
What have you searched for on the internet in the way of your Jeep issue that yielded no results?
I found a pinout diagram for the '09 ( same as yours) in 1.8 seconds by searching Google.
:nono:
Hi guys, I have a Haynes manual and the wiring colors are completely different and doesn't explain what the extra 3 wire connector might be, google search gives you tons of different schematics but nothing that matched my wiring colors. Maybe what you are getting at then is to disregard the wire colors and concentrate on the PINOUTs instead J3ff3ry. I read somewhere that if you have the subwoofer in the boot then you indeed have the Infinity system which my wrangler has. Thanks Treader I will follow this link and see what i can find.
