Hi,
Finally after a few years of waiting and getting side tracked with numerous other projects, I've started on the Hemi swap.
Last year I worked on the axles and suspension. The axles are completely rebuilt with 5.13 gears and a locker bypass. I have a 2.5" Teraflex lift with Fox shocks and 35" tires.
I know I'm going to need lots of help along the way, so I'm hoping some of you here already have the swap and the input will be invaluable.
The engine and transmission donor is a 2006 Commander. Which has a 160k miles. Yes, I know that's a lot of miles, unfortunately I'm on a very limited budget and that's what I could afford right now. Also I'm pretty impulsive with buying vehicles and if I waited to get something with lower miles, I'd likely just spend that money on something else.
The engine is getting a new oil pump, water pump, timing components exhaust manifolds/gaskets, plus a few other gaskets and seals and the usual tune up stuff. Transmission is getting new filters, sensors, and a new oil pan with a drain.
Commander was hit in the front and I did run the engine. I runs well with no unusual noises.
I have the JSS bolt in mounts, plus a few other items from them.
This will be a budget build and I'll do all the work.
I also think those fender flares look stupid, but that's for another time.
Thanks.
Thanks.
