2008 JK Wrangler - ENGINE AND ENGINE COOLING:ENGINE Jan 08
9964 Views 4 Replies 3 Participants Last post by  Brian
Component Description:
Bulletin Number: 0800108
Bulletin Date: Jan 08
Vehicle: 2008 Jeep Wrangler
Summary:
LONG ENGINE CRANK TIME AND/OR MIL ILLUMINATION DUE TO DTC P0340 / P0344. INVOLVES THE REPLACEMENT OF THE ENGINE CAMSHAFT SENSOR.
( NHTSA ITEM NUMBER - 10024059 )
asdfasd
Uh, Lance lists a long crank time (which my JK does) but Brian's PDF is for the clutch squeak?
Whoops....lets see if this works:
Weak...I can't attach it cause its too big as a PDF:pissed:
Okay, here it is in text...kinda hard to read, but it pretty much says if you have a long crank time, or a MIL for crank, or cam sensor, or a couple other things there is a software update for your pcm....and depending on your build date, you may need a new cam sensor.....take it to the dealer, tell them you have a long crank, and they will take care of the rest;)
