1 - 1 of 1 Posts
Vendor
Rancho® 2-in. Sport Suspension System for Jeep® Wrangler JK 4-Door
TL/DR
This system allows you to pair the Rancho shock of your choice with this proven system.
Pair with the RS5000X, RS7MT monotube or adjustable RS9000XL shock.
Check with your favorite retailer on cost :)
Get your 4-door Jeep® Wrangler JK Unlimited ready for a day on the trail with the Rancho® 2-in. Progressive Sport suspension system. This premium suspension system features front and rear progressive rate coil springs specifically tuned to deliver superior on-road comfort and off-road performance. Tested to comply with NHTSA FMVSS126, the kit works with the vehicle’s electronic stability system.
  • COMPATIBILITY -- Designed for 4-door Jeep Wrangler JK Unlimited
  • BUILT FOR THE TRAIL -- Designed to fit up to 33-in. tires, get 2-in. of additional ground clearance needed for trail riding or on-road driving (can accommodate 35-in. tires with trimming; aftermarket bumpers, sliders, winches, etc. affect lift height)
  • COMPLETE SOLUTION -- Front and rear progressive rate coil springs, front bump stops, rear brake line relocation brackets and mounting hardware; shocks sold separately
  • SUPERIOR PERFORMANCE -- Front and rear progressive rate coil springs, specifically tuned to provide superior on-road comfort and off-road performance
  • EASY TO INSTALL -- Bolt-on installation for an easy upgrade that complies with NHTSA FMVSS126 standards
  • COMPLETE PERFORMANCE UPGRADE -- Transform your suspension with Rancho geometry correction bracket (RS62103) or combine with Rancho adjustable control arms (RS66155B, RS66156B and RS66157B, RS66158B); sold separately
  • NOTES -- Compatible with Jeep factory electronic stability system, it allows the use of OE wheels and tires and is designed with 33-in. tires using 17-in. wheels with 4.5-in. backspacing (tire size varies between manufacturers)
  • BUY WITH CONFIDENCE -- Comes with Rancho’s limited lifetime warranty
Font Poster Recipe Advertising Menu
1 - 1 of 1 Posts
