Will Trade for Auto 05-06 TJ/LJ
Selling one mean TJ - This TJ is is clean condition and needs nothing - It was built as a DEMO vehicle for our company and has had little to no use at all. It has never been in the mud or swamped - we towed it to MOAB Utah in 2009 where we wheeled it through some of the nicest country in the world. This is a real fun size and its easy to own - The paint is a 8 out of ten and needs nothing but fresh wax (or mud). There are a few small dings on the hood from a branch falling on it, which was there when we got it and the grill has a slight crease in it, also there when we got it. Neither were enough to need body work and ultimately its a Jeep intended to be used off-road where your susceptible to a lot more damage. The interior is clean and does not show signs of excessive wear, the stereo is stock and so are the speakers. The interior fan switch stopped working on the low and medium setting, which is common and easily replaced. The soft top has no rips and is in over all good condition the windows are still clear, but a little elbow grease wouldn't hurt. The transmission shift solid and the transfer-case engages smoothly -
If you have question please call 718-442-4723 x 11
[email protected]
04 Wrangler X Automatic 4.0 -
*Banks Header
*Banks Air Intake
*MBRP Cat Back Exhaust
*New coil packs
*New water pump
*New O2’s *New injectors
*New fuel pump
*New radiator
*New idler
*New front and rear brakes
*4.88 Gears front and rear with new bearings and seals throughout
*Rock Locker Rear LSD
*Rock Krawler 3in Lift Suspension
*Rock Krawler Sway Bar Disconnects
*Rough Country 2” body lift
*Bilstien 5150 Shocks
*Old Man EMU Steering Stabilizer
*Riddler F/R diff covers
*Black Grill Inserts
*Genright Front and rear flat fenders
*Genright Lower Body Armor
*Genright Corner Guards
*Genright Steering Box shield
*Recovery Rear Tire Carrier with rear flood lights
*35x12.5x18 Pro Comp Extreme All Terrain 90% thread left
*Procomp 7105 Wheels 18x10 flawless
*Hella Blacks 6” windshield lights
*Delta Flat Black Headlights
*Black Headlight surrounds
*Rear Flood Lights
*LED Tail lamps
*SPOD Switch system
*Power Windows
*Rear LED third brake light
96k on the clock and runs like a top - not a miss in the idle and shifts strong... great rig deserving a great home.
Thanks, by the way the regulator right behind the glove box on the bottom of the fan box is why the switch is acting up change it out and your good to go. Just take a few minutes.
