1 - 1 of 1 Posts
Here is an awesome 2000 Jeep Wrangler TJ 5spd manual 110k miles 4.0 6cyl, Pro comp Short arm 4" lift kit, Pro comp shocks, 35/12.50/15 BFGoodrich All Terrain Tires (85%)
Jeep Cherokee high pinion Dana 30 in front with an OX Cable locker and 4.88 gears. Ford 8.8 in rear with LSD, disc brakes and 4.88 gears, JKS Sway bar quick disconnects, Toms driveshaft slip yoke eliminator with extra clearance, Nth tummy Tucker (raises transfer case), Nth stinger (three link), Nth slider (protects the rear diff), Dakota digital speedo interface (fixes too fast speedo and is adjustable if you change tire size), Six rock lights (rears are burnt out) using factory fog switch and heavy duty relay, Cb radio
Factory cd tape deck with aux input, Mtx blue thunder five channel amp, 10" kicker sub, Hood shocks ( there are no factory hood lifts on tjs), Yellow Top optima, K&N cold air intake, Throttle body spacer, Rear metal Tuffy expandable lock box, Tow hitch,
Please email me if you want more pictures.
Jeep runs great and shift perfect. Its only been offroad a few times but is very capable. Reg is good, title is clean.
818-720-3057
text me, call me or email.
$9500obo
1 - 1 of 1 Posts
