Assuming I go with a Teraflex BB lift.. what else do I need to complete the project?
adjustable track bars?
Wheel spacers - running stock 17" alum wheels
track bar bracket?
sway bar links?
longer brake lines?
I want to do it right if I do it.
Is there a kit that includes everything?
I've looked at dozens of posts and this old man gets dazed and confused
depends on what your goal is
if you want to run 12.50 wide tires with stock wheels, you need spacers
also there are at least 4 different TF BB kits
depending on how you want to address the shock issue- you can use your stock shocks and get one with shock extenders or you can use different shocks and get one that comes with nothing or you can get one that comes with TF shocks. If you're going to run a winch/bumper you can get the HD BB kit that comes with front springs instead of spacers.
The new BB kits come with a rear t-bar bracket, sway bar links and brake line brackets, so those are covered.
It really just depends on what your goals are.
x2 what Venom said.
Also, when I did the 2.5 BB I used the shock extenders. Most folks told me if I got new shocks it would provided more travel. I choose the extenders to be cheap (also the BB was temporary), but if it was permanent, I would consider getting new shocks.
Here's a video of it in action. You can see at the end the front tire comes off the ground.
