Well I have less than 2k on my JKUR and am having electrical issues. Starting last weekend the Prking brake light, ABS, stability control, decent control, sway bar lights blink on while going down the highway then within a second blink off again. Anyone had this? Any ideas? Dealer is at least 2 weeks from being able to see it
This happened to me... Kinda
http://www.jkowners.com/forum/showthread.php?p=3449961
It was an electrical issue... my battery cables had come lose and something about shooting high voltage to the ABS system... I had attached my LED Wiring harness to the wrong point on the battery.
http://www.jeepmomma.com/2015/07/jeep-dinging-flashing-esc-malfunction.html
I would check the battery connectors...
I looked this morning when I pulled in the garage and my negative wire is in the "wrong" position. I'll move it to the other post like in your picture where you labeled it "right" after work and see if that does.
Thanks for the info I'll keep you posted. Funny thing is I had a 2014 and never had that issue, but I may have had a not on the non clamping post and used that. Can't remember.
