1 - 17 of 17 Posts
Had my Jeep in to get the gas tank replaced per the 07 overflow issue. While I was there, had the dealer look at a water leak on both doors at the A pillars. (Jeep is a 2dr w/soft top.) The dealer uses a 3rd party contractor for leak issues. Got the call from the service dept later in the day and talked to the contractor. He said it would $600 for the parts and $450 for the labor to fix the leak. Little bit of sticker shock on that one, so I declined. When I picked up the Jeep, I asked to have a copy of the quote for the leak repair. The cashier whites out the actual cost, gives me a copy, then shows my estimate on a dealer quote sheet inflated to $750 for parts and $525 in labor. 1.) The initial $1050 seems ridiculous. 2.) WTF is with rewriting the estimate in front of me for $225 more?
Off to Home Depot for some $5 weather stripping...
you should have said something even if you werent getting it done, ask if they charge $225 to write something down. I hate every singe dealer i ever did business with except the one i bought my first 07 from and stupid chrysler closed them
As a fellow JKOwner, I'll do it for a grand. :thefinger:
Coonasian
The helping spirit on this board brings tears to my eyes! :gluging:
How did they say they were going to fix it? $1200 is a new top, which we have found will not fix water leaks most of the time.
Robert
Hmmm...you don't happen to have parts for sales do you?
I can get a hardtop for that kinda cash.
Just a thought:
Most auto repair services are bouncing off the $90-$100/hour service rate. Of course, some higher/lower. So the labor, pull your rig in at 8 am, tear down, repair, pull out by lunch, OFFER WARRANTY, may not be that far of a stretch.
Parts are another matter.
And the dealer isn't swapping dollars for free.
So, if you can't work through it yourself - GOOGLE. Find the dealer's contractor, and grind out a reasonable price direct.
Mine has a minor leak at the car wash and under really hard rain storms. Fuck it, I don't worry about it.
Discussion Starter #13
$240 in parts and a Saturday afternoon later, my Jeep no longer leaks. Just followed the directions on the Jeep Water Leak manual! Seems like the windshield header was the main culprit.
With half doors its about impossible to fox water leaks.....plastic junk..
I just took a razor blade and cut an X in each drain plug.
Or you could have just taken the plug out.
1 - 17 of 17 Posts
