While getting irritated while welding in my new exhaust I decide the rock magnet of an evaporative canister needed to be relocated. It fits perfectly above the axle with like 9-10 inches of clearance if you remove the bracket and run a flat plate from the 2 frame crossmembers.
I used an existing hole in the first cross member and ran the plate on top of the 2nd
The plate has tabs to prevent it from rotating and there is no way in hell that the 1/2 bolt will ever shear. Right now the zipties keep it from shifting, when I get around to it I will use a large hose style clamp. The lines WILL allow you to put it there and if you do need to replace the lines with FUEL SAFE hose from like a marine/boat place.
why skid plate when you can get it out of your way.
