1 - 9 of 9 Posts
Not sure what you mean by "on the range side".
Do you want the wire colors in the body harness that connects to the transmission, and the corresponding contacts in the sensor?
Hey thanks for the responce. I'm referring to the wires only for the range sensor not the temp sensor. I'm looking for wire colors and position. Off the top of your head do you know if the colors change for 07 to 08?
Maybe if I cut to the chase it would help. I have a Ls 5.3 and I'm wiring in a prndl controller and the wiring info I have shows two wrong colors.
I hope this is what you are looking for:
YL/DB = T41, pin 10, contact 1
DG/YL = T42, pin 9, contact 2
DG/DB = T3, pin 8, contact 3
DG/LB = T1, pin 7, contact 4
TRS SWITCH STATES
SLP T42 T41 T3 T1
P....CL...CL...CL..OP
R....CL OP OP OP
N....CL CL OP CL
D....OP OP OP CL
2....OP OP CL OP
1....CL OP CL CL
1 - 9 of 9 Posts
