181 - 200 of 300 Posts
After going back and watching a bunch of videos outside of Robbies shop where they are beating on them I see that it does appear to be very common and they do want to raise up quite a bit. It just feels weird when your sitting in it.
Ha, it feels weird in my pants every time it does it!! You do get use to it over time!
Discussion Starter #188
So how does it drive?
The last couple of days I have gone around the block a couple of times just feeling it out and checking for leaks. It does not have a current registration or plate on it yet so no real driving. The looser converter is gonna take some getting used to. It idles and runs fine but it has died a couple of times coming back to idle and has a slight hesitation / sputter/ pop if you give any pedal quickly. It starts back up immediately but not a problem I want to have in town.
I've got 2 lights on the dash, ESP and traction control lights are lit. Prior experience with those lights coming on after working on the jeep tells me that my steering wheel isn't centered.....but it is. So I'm kinda at a loss. I had the steering wheel disconnected for a lengthy period of time so maybe it's possible that the wheel is a full turn out? The thing is the turn signal cancels correctly like it's centered properly.
Any way to diagnose That?
Other than that I'm getting an appt at a tuner for a weekend soon and will trailer it there.
Having a custom tune by a person who knows what they are doing and right in front of you is the best money spent! Excited for you to see what kind of power you are putting to the ground. Any check engine light for not running 4 O2's and cats?
Steering: From what you think is center, count how many rotations to full lock left, then right. If I remember correctly it is 7 turns from lock to lock. If the steering box was disconnected and the steering wheel moved , it is possible to break the clock spring.
Discussion Starter #190
It will turn lock to lock no problem. I don't know the count but it will do it and currently the clock spring isn't broken. I need a way to tell if I have the steering wheel a full turn out or not.
Could the lights be from wheel speed sensors?
I have my clock spring sitting on the bench. I'll take a look at it when I get back out there and see if I can count the turns it has.
Discussion Starter #193
So I replaced one wheel bearing which comes with a new speed sensor and had them all unplugged at various points with the key on. The ABS light was lit until I went for my first drive and once it got a good reading from everything again it self cleared the ABS light. So I suspect that they are all fine.
On my 2010 clock spring, I get 5.25 turns from snug to snug. The only thing that locks it to the steering wheel position is a little plastic tit that sticks up and into the wheel itself.
I'd think if the ESP thought you had the wheel cranked a full turn going straight down the road at speed, it would be going berserk and applying the brakes to save your life for you.
We've all heard the stories of people taking an off ramp and the Jeep tries to send them off the road. And that's always with the steering wheel only off by a bit.
Discussion Starter #195
When I had this happen before it just disables the traction control and ESP / BAS. This is why the lights are perma on. In that instance the wheel was visibly off center though. Adjusting it straight fixed it up.
I turned full right and left and back to center and the wheel is straight and so are the tires. I would think that if I had the wheel an entire revolution off that it would destroy the clockspring. It is working properly though......
Discussion Starter #196
Just went around the block again, It just has a slight issue when giving pedal quick as I stated before but after you get past that it seems to be ok. When coming back down to idle from getting up to any kind of speed ( like 30mph) it wants to surge and act like its going to die for a few seconds before it catches its breath it seems. When it does that the vacuum also surges and I can feel it in the brakes. I gave just a bit of throttle to it on one of the back streets in the neighborhood that's not developed yet and............... it felt GOOD! lol. The converter flashed to 3k and stayed steady as it was just a pullin away. I did NOT get on it by any stretch, I'm talkin like maybe 1/3 pedal. Either way I smiled and neighbors across the way that were in their garages all stepped out to see who the hoodlum was. It sounds gnarly with that exhaust. Wouldn't change that for anything right now. I had though about switching them up to some spintech chambered mufflers but not now.
Sweet!
With some quality time on the dyno, you should be good to go.
Was anything ever changed in the trans tune for the converter?
Discussion Starter #198
Sweet!
Had to be from what Jon said. Not 100% sure but I think he consulted someone on some of the changes to make so it wouldn't fry the convertor. Either way im not going to do any real driving until I get it tuned. There is a shop around here that has a guy who regularly tunes LS based vehicles making some crazy power. He will dyno tune the engine and trans. Talking to him on the phone today I immediately had the same feeling that I did when I spoke with HOWE about the hydro steering. Within about 30 seconds you know you are talking to someone who knows wtf they are doing and you feel as if you are in the right hands for the job. I've go an appt. for 10am this Sat. Another $500 cash thrown at it.
Discussion Starter #199 (Edited)
So, I went to the dyno on Saturday and got some tuning done. This motor has exactly 2 miles neighborhood driving on it and maybe about 30 minutes total of running time on it in the garage. I had mentioned this to the tuner and expressed concern about beating on a new engine. After some discussion I just relied on his experience and the tons of new engines that he tunes. The tuner owns a local shop here in TX that mainly builds and tunes high end late model GM vehicles like vettes, camaros, etc... There were 3 near new vettes in there that were all procharged laying down over 1300+ HP on stock trans and bottom end motors. I also stated that the new 40" treps had exactly zero balancing on them and he said that he has tuned some rock bouncers that were the same way and it wasn't an issue. He warmed it up on the dyno and once the flat spots came out of the tires (bias ply tires) they were actually running really smooth from the outside looking in. While it was warming up he noted to me that he thought that whoever did the original tune (Jon) did a good job as far as integrating all of the peripherals and he hadn't seen the tap shift setup like it was before and he liked that. The actual tune though while I thought it wasn't far off wasn't really close either. No fault of Jon's as it ran good enough to get going, you really need to have any custom setup like this professionally tuned unless you drop in a stock motor with all stock setup including identical to stock intake and exhaust. After a couple of hours of messing with it he got me 360rwhp and a few less Tq. I am satisfied with that considering the weight of the wheel/tire combined with typical drivetrane loss. He had mentioned that some of the rock bouncers that come in with supposed 600+ hp LS engines have layed down sub 300 hp on the dyno due to all of the massive components that soak up power before it hits the rollers. He made the pulls in 3rd gear and at 6k rpm it was 86mph, lol. Its sketchy standing near something like that. My sense of preservation starts to kick in and I ducked behind one of the nearby lifts when he made the pulls.
Glad you are making good headway on the tune and all. Ready to start putting some miles on it? I really want to do a dyno tune but dont see it in the near future, so I just keep working and trying to learn this hptuners and doing the street tuning.
