1 - 20 of 300 Posts
I've never been particularly good at keeping up with one of these types of threads. I usually just do an entire project end to end and then post pics and answer questions. I will try to keep up with this one for any who are interested. Please bump the thread or ask for updates if I am lacking. I will take pics of anything interesting, tricky stuff to deal with, or anything you would just like to see. This is the best site I have found pertaining to info about the swap itself. We have the 2 premier vendors IMO for this swap here and active on a daily basis answering questions and sharing knowledge. This by itself is invaluable and had I not have had the chance to pour through miles of threads I wouldn't have felt comfortable taking this on.
With all that said, there aren't a ton of individual build threads here for guys like me who are just dangerous enough with a wrench and just optimistic enough to try and tackle this job in their own 2 car garage with the body on. My recorded attempt at this starts now.
Discussion Starter #2 (Edited)
GMPP LS3/ 525 P/N: 19301360 $7020
6l80e trans 14k miles $1825
Torque convertor 3400 stall (EDGE racing) $870
RPM EXTREME HD radiator $900
pentastar fan P/N: 68143894AB $378
GM pedal P/N: 25832864 $65
GM motor mount x2 P/N:15854941 $181
GM accessory drive P/N:19299070 $592
sanden a/c compressor P/N: 7176 $210
RPM kit, a.c hoses, and CAI $5645
Dirty dingo A/C bracket P/N: DD-LS-AC-LM $142.99
Dirty dingo comp fitting adapter DD-SD7B10-F $48.99
Transmission Dipstick Seal P/N: 15796802 $6.25
Transmission Pan Gasket P/N: 24224781 $17.81
vacume hose nipple P/N: 12559760 $10.60
Power Steering Pressure Hose P/N: 22790848 $62.11
Transmission Filter P/N: 24236933 $34.73
Starter P/N: 12617229 $112.10
MAF Sensor P/N: 15865791 $52.99
o2 sensors x2 P/N: 12583804 $96.32
Trans inspection cover P/N: 24261713 $11.39
Trans dipstick tube P/N: 24260606 $18.20
Starter bolts x2 P/N: 11610787 $9.25
ARP bellhousing bolt kit P/N: 134-0902 $27.68
GM bellhousiung bolt / stud P/N: 11609419 $5.28
weapon R catch can P/N: 826-134-101 $59.50
GM E38 ECM P/N: 12633238 $89.99
Hinson plug wire heat boots $54.84
Alternator connector $20.99
Battery box for 12+ MOPAR P/N: 68079473AG $110.50
ARP exhaust collector bolts P/N: 400-1215 $39.99
ARP headder stud kit P/N: 434-1301 $108.33
3" stainless x pipe (ebay special) $49.53
RPM EXTREME ceramic headers $595
Borla XR-1 mufflers x2 P/N: 40943 $301.98
Sanderson 3" gasket P/N: SHN-COPPER3 $35.00
Pypes 3/8" stainless flange x2, P/N: HVF13S $26.72
o2 bungs stainless M18 x 1.5 $12
Verocious Motorsports mandrel bends $453.27
2x 3", 90 degree bends on 3" radius
2x 3", 45 degree bends on 3" radius
3x 3", 4' long tubing
4x 1/2" rubber exhaust hanger
4x 1/2" exhaust hanger rod
8x 3", 45 degree elbows
Earls 585106ERL cooler adapter -6 fittings $19.85
Earls 19 row cooler 81900ERL $215.95
Earls cooler mounting kit 1508ERL $49.94
-6an trans cooler adapter EBAY $49.00
GM trans cooler gasket P/N: 15251488 $7.67
WIX fuel filter P/N: 33737 $29.63
RCI fuel cell P/N: 2161A $224.97
Aeromotive pump asembly P/N: 18688 $438.47
Aeromotive port plug P/N: 15626 $11.99
Artec fuel cell brackets P/N: FM2161 $120
Aeromotive pressure gauge P/N: 15633 $29.84
Aeromotive port fittings x2 P/N: ORB-06 $27.60
Earls -8an cap x2 $11.72
Earls pressure gauge adapter AT100199ERL $23.39
Earls -6 TO 3/8 QUICK DISCO with 1/8" port $54.58
P/N: EAR-AT992066ERL
male -6 AN to 3/8" male Quick Connect $13.97
Aluminum, Black Anodized P/N: FRA-491994-BL
Earls Quick Disconnect OEM Fuel Line, $69.10
Male -6 AN, Straight, Aluminum, Black Anodized
x2 P/N: EAR-AT991966ERL
So basically the actual work for this started for me on a Friday 11/18/16 for those who are counting. This is the date I drove the jeep into the garage for the last time with its original engine and started to take it apart. I won't bore you to death with details on that. I will say that I had to remove the transfer case from the transmission from below before I could pull the engine and trans out together. Also if you are using just a regular cherry picker type of engine hoist I had to cut the crash bar out and remove the sway bar to be able to push the hoist far enough in to be able to hook up on the engine/trans in a good spot.
This wasn't really a big deal to me as the new bumper I want had me removing it anyways.
Between the crash bar and removing the original motor mounts it took me about 2 hours to grind the welds, knock the brackets off, and smooth out the frame. Nothing particularly exciting about it.
Good luck and have fun. I know I enjoyed doing mine. Unfortunately I am horrible at doing threads as I get to involved once I get started and forget to take pics or even update a thread. Glad to see you doing this. If I see or think of anything I will be sure and post it, never know it might help out.
Discussion Starter #10
I am prepping to get the engine and trans in and get the new frame mounts welded in this weekend. I got the transmission crossmember fitted with the new brackets and had moved on to the transfer case adapter when I noticed that the small L shape bracket that attaches to it for the mount was not sitting flush. There is a raised area that will not allow it to sit flush. I have 2 ways to rectify this.... Either I use a washers to space it out a tad or I grind the excess away. I had to double check what side of the adapter it mounted to and according to the pics in the instructions it's on this side.
It goes on the other side, facing the other way.
So. L shaped bracket mounted on the front side of the lip with the L facing to the rear.
It's pretty universal and you could mount it any way you see fit especially since you have a 2 door and you may be moving the engine forward slightly. I would get the crossmember bracket mounted and drop the power train in and then lay out the mount and bracket.
Is that a 2 or 4 wheel transmission? If 2 wheel don't forget the plugs and seal before you put the transfer case adapter on. Also check the length of the transmission output shaft. It should be around .500" past the face of the transfer case mount, attached. If not you will need to shorten it.
Discussion Starter #13
I figured there was something I was missing. The pics in the instructions show it the way I have it in the picture. With me trying to push the engine forward it makes sense to turn it around the other way.
Discussion Starter #14
It's a 4wd trans from the get go. Plugs and seal are present.
What kit did you end up going with? I just put a 6.0 and 6l80 in my jku last month with the body on also. I went with motech's kit. Its a tight fit everywhere but I LOVE the extra power now! I am running 5.13's with 37's so that helps also. :)
Discussion Starter #16
I got the RPM extreme kit. No complaints yet, I would have probably figured out the bracket once I stabbed it in there and looked at how everything was lining up. I am trying to put the cart ahead of the horse a bit with some of this stuff in an effort to save time later but I have a feeling it will just cost me more down the road. I'm just anxious to move forward with it.
Discussion Starter #17
Does anyone think that I should replace the lip seal or this O-ring on the transmission before I mate it with the engine? The trans has 14k on it.
Also what is the proper amount of fluid to dump into the convertor prior to installing it? It is a brand new convertor.
Discussion Starter #18
Updated post #2 with some part # info and what I paid for each of the items shipped to the door. This is what I have so far that I know of for the swap. I am sure there are some misc smaller items I have forgot about. I do not own any radiator hoses for this yet nor any of the several gallons of misc fluids needed for cooling, engine, and trans. I still have to have the exhaust fabbed up and I need a rear driveshaft, trans cooler, and associated lines.
Discussion Starter #20
So this may be my first real work around on this project and to be fair it was not a surprise that this would possible be an issue. The issue is that using the offset accessory drive that I have (cts-v) which is the same as the vette offset that the a/c compressor is pushed back just far enough that 2 of the 5 bolts that hold the end cover onto the compressor interfere with the frame side mount.
What it appears that I will have to do is either clearance out the frame side mount for the heads of the 2 bolts to extend into or.... machine the cover of the compressor to accept a socket cap head screw and countersink the register for those 2 bolt heads slightly into the cover while I shorten the heads of the bolts as well.
I think I will choose to do the machining as I do not like where the bracket will need material removed. On top of this the hole for the bolt heads in the bracket will have to be larger than needed due to engine vibrations etc... it will need excessive clearance so a bolt head does not slap the mount. I don't need the a/c compressor cover being compromised because the a bolt head was slapped off it.
1 - 20 of 300 Posts
