Does disconnecting the battery get you going each time?its been happening more frequently lately but our temps in utah have been in the low single digits in the morning and 30's in the day. it almost seems like it may be a different problem with every light and chime going off at once
Have you talked to the dealer yet? Even if you have to pay them, there is a point when you just want your jeep to work.the first couple of times disconnecting the battery would allow it to start. the last time it happened disconnecting the battery didn't work, and i had to leave the jeep at work. the next day the battery was completely dead. after recharging the battery it started right up and has run for a few days just fine. the more i read about it the more everything points to the TIPM.
I have experienced this in my 2009 Rubicon Unlimited a few times.I purchased it in Dec. 2008 .Need to check build date.Antitheft System - Engine No Crank/No Start Condition
NUMBER: 08-007-08 REV. A
GROUP: Electrical
DATE: July 04,2008
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-007-08, DATED MARCH 04, 2008. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
DO NOT ORDER PART NUMBER 05026070AP UNTIL JULY 21, 2008. ALL OTHER PART NUMBERS ARE AVAILABLE NOW.
SUBJECT:
No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
OVERVIEW:
This bulletin involves the replacement of the Wireless Control Module (WCM), and if equipped, the replacement of the Electric Steering Column Lock (ELV). The WCM is also referred to as the Sentry Key Remote Entry Module (SKREEM).
MODELS:
2007 - 2008 (JK) Wrangler
NOTE :This bulletin applies to vehicles built on or before May 05, 2008 (MDH 0505XX).
SYMPTOM/CONDITION:
The customer will experience a no engine crank AND a no engine start condition. Also, the remote keyless entry (RKE) system will not operate. This condition may be due to an electrostatic discharge (ESD) from the ignition key into the Wireless Control Module (WCM), causing the WCM to electronically lockup. This condition may occur more frequently in dry and/or cold weather conditions where a sufficient electrostatic charge is more easily produced. This condition is corrected by the replacement of the WCM.
mine does it all the time but because it isnt a recall jeep said tuff shit
My 08 Rubicon Unlimited is doing the "no start" dance more and more recently. I hadn't read this thread till just now, but the way I've been getting it to start is to put it in neutral, roll it forward or back just a tad, then put it back in Park and wham-o....it has started every time.is this the problem when you first try to start your jeep? It makes a like half starter click sound? Is this the one where if you put it to neutral, and back to drive, it will start up? just making sure that i got the right tbs, because my jeep is doing it now.....
I don't know that is is the antitheft issue. It sounds more like neutral safety switch. I have almost the same issue a lot where it does not want to start in park. If I push forward on the gear shift or put it into neutral then it starts.My 08 Rubicon Unlimited is doing the "no start" dance more and more recently. I hadn't read this thread till just now, but the way I've been getting it to start is to put it in neutral, roll it forward or back just a tad, then put it back in Park and wham-o....it has started every time.
Does anyone know if this no start issue would be covered by an extended warranty? I have 60k so I'm out of regular warranty, but have the extended care warranty up to 100k.
Same. I'll get it intermittently, cycle the tranny shifter from Park to 1 and back, restart, good to go.I don't know that is is the antitheft issue. It sounds more like neutral safety switch. I have almost the same issue a lot where it does not want to start in park. If I push forward on the gear shift or put it into neutral then it starts.
Sounds about right...... :flame:So far jeep put in 3 tarers said it was the loose nut syndrome that the commanders hae where the jumper wire nut is left loose from chrysler that wasnt it and they put in a starter harness and made the most rigged ground wire from the inner fender to the block out of 12g wire but it was about 3ft too long and it melted to my cat and thought the truck was on fire lol, would be too good to be true. Now a chrysler tech rep has to come and look at the heep.
