1 - 20 of 98 Posts
Custom Adapters and Spacers
BORA Adapters - Off-Road Adapters, by Motorsport Tech.
Since 1996, Motorsport Tech’s Adapters and Spacers have been designed, built, tested, and proven in the toughest conditions on Earth - We’ve outfitted vehicles in the US Military for combat duty, desert racing pre-runners, Arctic rescue vehicles, major auto companies including Ford, Chrysler, and Goodyear, and have built parts for thousands of hardcore off-road enthusiasts around the world - including our own vehicles we drive daily.
With our experience and acquired knowledge over the last 15 years, along with a recent expansion of our in-house production facility, we thought it was time to introduce a new 4x4 specific line: BORA. BORA stands for Bulletproof Off Road Adapters. And that’s just what they are. BORA adapters will be built to the same exacting standards of all Motorsport Tech parts (Made in the USA with Alcoa aluminum on state of the art American made Haas CNC machines) but now at a lower price!​
BORA JEEP JK
5x5 • 1/2" x 20 Studs • Hub Bore 71.5
.750" - Set of 4 - $190 - Set of 2 - $95
1.00" - Set of 4 - $190 - Set of 2 - $95
1.25" - Set of 4 - $200 - Set of 2 - $100
1.50" - Set of 4 - $210 - Set of 2 - $105
1.75" - Set of 4 - $230 - Set of 2 - $115
2.00" - Set of 4 - $280 - Set of 2 - $140
If you have a custom or unique application, BORA adapters can be made to order to your exact specifications.
We Will Beat the Price of any other American Made Adapter or Spacer!
BORA - Bulletproof Off-Road Adapters and Spacers.
__________________
www.motorsport-tech.com
Like us on Facebook
(775)351-1000
Discussion Starter · #4 ·
The mounting thickness stays the same. The spacer width can change to whatever you may need. The spacer will have pressed in studs to bolt the wheel up. We supply the hardware to install the spacer to the Jeep. Let us know if you need anything and we can custom make any size.
I guess im missing something, because if the spacer width is less than the stock lug length then the wheel wouldnt sit flush against the spacer
Discussion Starter · #6 ·
We can make the smaller spacers for certain specs. Those you would have to trim the studs down. We send our spacers out with an open end bolt which will fit inside the spacer. The more common ones we build our 1.25" or 1.50" for Jeep. It all depends on what you need. What size are you looking for?
Maybe a silly question, but do the spacers come in colors and if so, why? can you see them when looking at the wheels? Just interested ... looking to get spacers in the future... thanks.
Discussion Starter · #13 ·
We can anodize them in many colors, it's an extra charge. The BORA line comes in the black finish. People have asked for the color to match. Depending on the set up or the wheel some you can see.
Mark
1 - 20 of 98 Posts
