Welcome to the Forum!
What engine cooling temps are you seeing on your EVIC?
Can confirm it’s a programming issue, I had the same symptoms on my Edelbrock setup. The fan eventually failed and it was a $700 part a couple years ago.Guess I should’ve called Edelbrock as soon as I replaced the first tstat. Tech told me they program it that way on purpose so it comes on when it gets to temp since the Supercharger adds heat to the system. Guess the Jeep had troubles longer than I knew. Hope someone else can read this if they have the same set up and run into this issue.
