Transfer Case Linkage Fix - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By rob4607
  • 1 Post By Uncle Sams Misguided Child
post #1 of 15 Old 09-22-2012, 08:01 PM Thread Starter
As some of you have probably learned the transfer case linkage on our JK's isn't very well designed. Thought Id show an easy way to fix it that cost about $10.00.
I got these from Oreillys but I'm sure you can get them at just about any auto parts store.
First I dropped the transfer case skid to get access to the broken linkage.
Now taking the smallest bushing use a 5/16" drill bit and use it to open up the hole in the bushing.
After you drill out the bushing put it into the opening on the shift linkage cable and slide it onto the stud that's on the shift lever so that the flat end is facing out, away from the transfer case.
Next find the E-clip that measures 3/8"
Now you simply push the E-clip on to the shift lever in the grove that is already on the stud.
That,s it, takes about 20 min to do and there's enough to fix both ends. Only difference is when using the bushing that is the next size up you'll need to shave down the outside of it so it will fit into the opening on the shift linkage. Been running this fix on the other end of my shift linkage for over a year now with out a hitch.
HOT_DAMN is offline
post #2 of 15 Old 09-25-2012, 09:53 AM
SoonerTA's Avatar
Great write up! Mine just broke at the shift lever when in 4Lo and after wheeling had to go under the Jeep and through the t-case lever forward to go home. Not so much fun with the exhaust right where your arm needs to go. I will be doing this to my rig this weekend. Thanks again for the write up!
08 Unlimited, Auto
Red Rock Crystal
Rubi Sliders | 2.5 RC Lift | RC Q-Disco's | Misc Skid plates | Hella Black Magic | MBRP Windshield mount | CB with Firestik LG3-M2 mount w/ 3' Firestik | 285/70/17 MT's | 17x9 Xd Series Matte Black Addict
TexasJK.com
SoonerTA is offline
post #3 of 15 Old 09-30-2012, 08:46 AM
SoonerTA's Avatar
Thanks again for the write up! Took about an hour for both...Including beer brakes and it raining outside.
FYI, In the bushing kit there is only one of the smallest bushings that work. I had to sand down, outside diameter, the second to the smallest bushing to do both sides. You do have enough e clips. Thanks again!
08 Unlimited, Auto
Red Rock Crystal
TexasJK.com
SoonerTA is offline
post #4 of 15 Old 11-04-2012, 01:23 AM
Doing this project next weekend
post #5 of 15 Old 11-04-2012, 05:09 AM
So this will fix my hard time trying to put it into 4hi and lo?0
Sent from my iPhone 5!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42” MTR's
17" Spyderlock Beadlocks
post #6 of 15 Old 11-04-2012, 05:25 AM
No. That's user error imo. This will keep the bushing from popping and your shifter going limp.
post #7 of 15 Old 11-04-2012, 05:39 AM
Really goody... User error... I know how to use the t-case system... So I will find another solution! Thank you!
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #8 of 15 Old 11-04-2012, 05:45 AM
I can get mine to shift pretty smooth, so yes really. It is not a fully synchronized system between 4hi and 4lo. The transfer case linkage breaking is primarily due to people trying to force the shifter, rather than slowly rolling and letting it fall in. A simple cable linkage isn't going to cause a hi to low problem, if you tried to do it by hand on the transfer case lever you could get it to bind up..but what the hell do I know? Good luck with your transfer case hi/lo internal synchronization mod. I'm not trying to be an ass, but I rather not see you waste your time and effort trying to "fix" something that isn't there.
post #9 of 15 Old 11-04-2012, 05:50 AM
Yes user error, I have a rubicon and after many times of practicing over and over, I can now constantly shift it from 2wd, to 4wdh, then 4wdl and back with just two fingers. It's like a woman, you have to find its sweet spot. And no, spitting on it won't help.
j3ff3ry_j33p likes this.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #10 of 15 Old 11-04-2012, 08:52 AM
I am sorry for before... I went out and gently put it into 4hi and 4lo... Apparently I was trying to slam it in.... Damn it... Thanks for helping! Haha should this fix be done for precautions?
-Marc
Coming up:
EVO Long Arm
40/42” MTR's
post #11 of 15 Old 11-04-2012, 08:54 AM
I did, it's a good idea. Mine was a little different but this should do it just fine.
post #12 of 15 Old 10-14-2015, 12:48 PM
Great step-by-step instructions. It took all of about 15 minutes to repair mine. Thanks!
sfrank is offline
post #13 of 15 Old 05-23-2016, 12:15 PM
Thanks for the pics!
Question: I just bought a 07 rubicon 2dr and broke the transfer case linkage the moment i got it into the driveway FML.
How it happened: I shifted from 2h to 4h and to 4L while stationary. The case proceeded to freeze up and had to force it into neutral. From Neutral it refused to go into any other drive mode and I eventually snapped the linkage trying to get out of neutral.
The Jeep became stuck in neutral and i had to call tow.
Luckily the dealer warranty is covering the fix but I'm wondering if I need to be concerned about any other damage that resulted from the freeze up? Also, how do i avoid this in the future?
I saw a little bit of fluid dripping from the bottom of the transmission after this happened did I possibly blow the transmission or the transfer case? Thanks for the help. -Joe
jgdyer90 is offline
post #14 of 15 Old 05-23-2016, 12:43 PM
Dutchboy101's Avatar
I've had the same zipties holding on for about 5 years now. On both the transfer case side and inside with the shifter. Never had an issue.
Dutchboy101 is offline
post #15 of 15 Old 05-23-2016, 01:37 PM
Highly unlikely that you broke the transmission or the transfer case. I am sure that the linkage broke way before you did any damage to them.
jgdyer90 likes this.
