DIY Aluminum Front Bump Stops - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 07-14-2012, 06:39 PM Thread Starter
alex00's Avatar
I'm getting impatient waiting for my lift to arrive, so I decided to take a stab at making my own bump stops. I ran down to the local scrap metal store and bought a 2.5" x 9.5"ish aluminum cylinder for $15. Borrowed my buddies DeWalt chop saw and got to work. Using a $5 center finding tool and a selection of drill bits, I made quick work of it.
Running a line of masking tape down the length made the cut marks much easier to see. A smaller pilot hole made countersinking the holes much easier, than trying to do it after the bolt hole was drilled. Cut the pucks, mark the centers, drill a pilot hole, countersink for the bolt head, and drill the bolt hole. Lather, rinse, repeat. The chop saw and drill press cut through the aluminum like butter.
alex00 is offline
post #2 of 18 Old 07-15-2012, 02:31 PM
rdlynch2's Avatar
You wanna make me a couple 2 inchers on the cheap?
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #3 of 18 Old 07-15-2012, 03:21 PM
What blade did you use on that saw for the aluminum?
post #4 of 18 Old 07-15-2012, 07:30 PM Thread Starter
alex00's Avatar
It's the DeWalt 7747 blade, 70 tooth metal cutting blade. It's the one that came with the DW872 saw. This damn saw cuts circles around my DeWalt with abrasive wheel. I may end up buying one. I'm sure at some point my buddy is going to want his back.
alex00 is offline
post #5 of 18 Old 07-15-2012, 07:34 PM
Nice, those are extremely nice saws..unfortunately the saw and blades are $$
post #6 of 18 Old 07-16-2012, 09:44 AM Thread Starter
alex00's Avatar
I'm finding that out. I've been searching for one, and can't seem to find them less than $450 shipped. Blades are another $100. My friend picked this one up off CL, for significantly less.
alex00 is offline
post #7 of 18 Old 07-17-2012, 06:18 AM
JWP
JWP's Avatar
I've been told by the shop I buy my metal from they get more cuts from them than an abrasive blade. It's hard to believe, and even if it's not true, the ease of cutting, cooler temps, and lack sparks is a nice. Definitely on my wish list.
I just now wish I could find some aluminum that size in small quantities.
How did that paddle bit survive the countersinking process.
2011 Rubicon
Teraflex leveling kit
Smittybilt XRC Flares
17x9 Mickey Thompson Classic II's
35x12.50-17 Goodyear MTR
JWP is offline
post #8 of 18 Old 07-17-2012, 08:35 AM Thread Starter
alex00's Avatar
I was so sold on the saw I found one at a local pawn shop and bought it. Saved a couple hundred off the new price. Let's see if it lasts. What bugged me about the abrasive saw was that the blade always deflected, so my cuts were slightly crooked. That, and they wore down quick on thicker metal.
That paddle blade worked like a champ. It made it through six bump stops and didn't show any signs of slowing down. I figured it wouldn't work, but had extras so it was worth the sacrafice. The big difference was the pilot hole. If I used the paddle after drilling the bolt hole, it wobbled around too much. Small pilot hole, and it was smooth and straight.
alex00 is offline
post #9 of 18 Old 07-17-2012, 09:53 AM
JWP
JWP's Avatar
Also an issue I have with abrasive saws. Home Depot is selling one of these saws now too, I don't recall the price but it wasn't the 400+ that Northern Tool gets for the DeWalt or Milwaukee
2011 Rubicon
JWP is offline
post #10 of 18 Old 07-17-2012, 01:00 PM
Also the abrasive won't play too well with the aluminum either.
Sent via paper airplane
post #11 of 18 Old 07-18-2012, 10:43 PM
RODICON's Avatar
Great Job!
2014 Rubicon on the build!
RODICON is offline
post #12 of 18 Old 08-01-2012, 09:35 AM
rdlynch2's Avatar
Theounter hole is 7/8ths, what is the size of the bolt hole itself?
rdlynch2 is offline
post #13 of 18 Old 08-01-2012, 09:48 AM Thread Starter
alex00's Avatar
Yeah... About that. I realized I made a mistake. I actually need to make the outer hole about 1 1/8" to fit the socket for the bolt. I drilled the bolt hole at 1/2", and guess what size socket I measured.
alex00 is offline
post #14 of 18 Old 08-01-2012, 10:40 AM
rdlynch2's Avatar
Alright, so 1 1/8th counter hole, half inch bolt hole. Got it. I got the alumimum cut already, I just need to drill the holes at some point today. To the hardware store I go
rdlynch2 is offline
post #15 of 18 Old 08-01-2012, 10:41 AM
rdlynch2's Avatar
Oh. One more thing, how long are the bolts you used?
rdlynch2 is offline
post #16 of 18 Old 08-01-2012, 10:44 AM Thread Starter
alex00's Avatar
I went with 3 inch bolts. There was plenty of room for longer so you can get a 3 1/2" bolt if you want. Just make sure you measure the socket you are going to use for the 1/2" bolts, and go a hair bigger on the spade bit.
alex00 is offline
post #17 of 18 Old 10-16-2012, 09:28 PM
Freshmeat's Avatar
Very nice write-up! I'll talk to a few of my machine shop customers and see if I can get a couple small sections of aluminum to make my own. Been doing fine without, but just flipped my drag link and need to keep the new equipment off the frame.
1988 Wrangler YJ, Q78-15s, some of this, some of that...
2014 Grand Cherokee Limited, EcoDiesel, RWD...
2013 RAM 1500 4x4, more buttons that I'm usually allowed to touch...
2007 JK X, just getting started...
Freshmeat is offline
post #18 of 18 Old 10-22-2012, 10:03 AM
TrailDuty.com
PhilD's Avatar
Nice work! If you want to use a smaller hole for the bolt, use a hex cap bolt.
PhilD is offline
