Water Pump replacement for 2007 Jeep JK Wrangler 3.8L V6 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 04-16-2012, 03:48 PM Thread Starter
Has anyone replaced a waterpump for their jeep? If so, how easy is it and can you post a write up? Thanks....
lbritt79 is offline
post #2 of 4 Old 04-23-2012, 01:25 AM
b1pig's Avatar
i dont have any pics. very easy.
just be mindful not to overtighten the bolts.
leave belt on while breaking the bolts loose. it helps...
used a screwdriver leveraged between the bolt heads and the center stub of the pump to keep the pump from turning while i broke the bolts loose. then took the belt off.
i dont recall anything special. didn't take any pics.
drained radiator into huge pan. reused most of the coolant. got one jug of HOAT from the parts store and topped it off.
b1pig is offline
post #3 of 4 Old 04-23-2012, 06:36 AM
The other info I posted did not help?
Not sure if they are out yet but from you local parts store a haynes/chiltons manual is a good 15-20 purchase.
beedle4 is offline
post #4 of 4 Old 04-23-2012, 08:03 AM
08rubicon's Avatar
I have a done a bunch on the old 4.0L don't see the 3.8 being much different. I would suggest replacing the thermostat while you are at it. If you are mechanically inclined you will not have any problems. Make sure you keep track of where each bolt came out from because if it's like the 4.0 not all the bolts are the same length. Good luck post up any questions.
2012 Unlimited Rubicon
08rubicon is offline
