Poison Spyder BFH - Support Plate - JKowners.com : Jeep Wrangler JK Forum
post #1 of 40 Old 04-06-2012, 12:55 PM Thread Starter
In light of a recent thread about a BFH getting a handle on the frame, I decided to at least tie the two bolts together.
https://www.jkowners.com/forum/showthread.php?t=72782
What happened here was the front bolt essentially pulled through the frame since it is the only one that is directly tied to the bottom of the bumper. The purpose of this support plate is to tie both bolts together, increasing the resistance of this happening pretty substantially. With a comp stinger on mine, I have a bit of leverage on those bolts!
There is a weld as you can see where the two plates over lap. There is also a 1/2" plug weld on the back side (see diagram) where they overlap. Obviously it's not painted or cleaned up in the picture...but you get the idea.
Edited the original post to updated picture URLs
post #2 of 40 Old 04-06-2012, 01:16 PM
that_guy's Avatar
Good job! This is one of those "why didn't they think of that in the first place" things
09 2 DR Rubicon
my JK is my addiction
that_guy is offline
post #3 of 40 Old 04-06-2012, 01:19 PM Thread Starter
It happens. They could have left it open to help with tolerances but never went back to revisit the idea. The plate will at least make you have to pull both through. With the comp stinger on mine and the way it was bolted on, I'd be tempted to think the frame bolt would pull through before the stinger bent if I hit something hard enough.
post #4 of 40 Old 04-06-2012, 03:14 PM
True Life's Avatar
Good idea I'll have to use that when I get around to fixing it up
I am here: http://tapatalk.com/map.php?ni3ixz
True Life is offline
post #5 of 40 Old 04-06-2012, 03:35 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Way to rocket through a solution Mike! Not to bash PS, but it certainly makes me feel like not going with the BFH was a wise move after seeing that other thread.
JKCTAZ is offline
post #6 of 40 Old 04-06-2012, 04:17 PM
RIP Brad
abendx's Avatar
Good job Goody! Might have to fab that up for mine.
abendx is offline
post #7 of 40 Old 04-06-2012, 06:54 PM
e-jeep's Avatar
Feedback: 12 reviews
I like it ...thoughts about welding a bar across the width of the BFH with matching bolt holes. Kind of acting like an added crossmember tied into the bumper?
Or would it be better to just weld the fucker to the frame?
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #8 of 40 Old 04-06-2012, 07:41 PM Thread Starter
Flat bar? Wouldn't add any torsional strength really. Cross member would need to have square/rectangle/tube type design to be much of any help.
You could weld it to the frame..
post #9 of 40 Old 04-06-2012, 07:54 PM
e-jeep's Avatar
Yeah ...I see what you're saying. So, gonna follow in your footsteps brother!!
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #10 of 40 Old 04-07-2012, 02:57 PM
True Life's Avatar
I was thinking about squaring off the front of the frame with some rectangular tubing along with goodys solution I'm just trying to figure out the Cleanest and strongest way to repair my frame
I am here: http://tapatalk.com/map.php?4ixk0w
post #11 of 40 Old 04-07-2012, 03:14 PM
JKrazed's Avatar
Feedback: 13 reviews
The skid plate also does the same as your bracket.
PROUD to be an
JKrazed is offline
post #12 of 40 Old 04-07-2012, 03:17 PM Thread Starter
Those pics don't show it too well, But that is good to know. I haven't seen many that run the skid
Sent via paper airplane
post #13 of 40 Old 04-07-2012, 03:43 PM
True Life's Avatar
You know that's exactly what was wondering if thats why psc designed it that way. To promote the purchase of the skid haha
I am here: http://tapatalk.com/map.php?xf2ond
post #14 of 40 Old 04-07-2012, 04:44 PM
JKrazed's Avatar
Yeah, here's some closer pics.
PROUD to be an
JKrazed is offline
post #15 of 40 Old 04-07-2012, 04:52 PM
NascarRubicon's Avatar
so you bmw guys dont just play with computers...
good thinkin and work goodies
"Eat Liquid Gold"
NascarRubicon is offline
post #16 of 40 Old 04-07-2012, 04:55 PM Thread Starter
That'll certainly help.
Hey now, BMW guy gone back to earn an Engineering degree . Just starting out in that aspect though..
post #17 of 40 Old 04-07-2012, 05:14 PM
now youre talking above my pay grade
"Eat Liquid Gold"
post #18 of 40 Old 04-07-2012, 08:29 PM
Thisguyhasadd42's Avatar
nice write up goody.
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #19 of 40 Old 06-13-2012, 02:12 PM Thread Starter
post #20 of 40 Old 06-14-2012, 07:05 PM
petef550's Avatar
I saw this a while ago but I admit I'm lazy BUT big but I went and got some steel today and I'm gonna do this tomorrow great write up.
its all about the crawl ratio.
petef550 is offline
post #21 of 40 Old 07-17-2012, 06:12 PM
nicholsmf's Avatar
Mine doesn't look as nice as yours but I was in a hurry. I just cut some 1/4" steel diamond plate scrap to size then drilled and slapped it in place.
2010 JK - Rock Krawler 2.5 Max Travel Kit - Fox 2.0 IFP Shocks - 37" Nitto Trail Grapplers - Genright Aluminum Tire Carrier - Poison Spyder Front and Rear BFH Bumpers - Warn M8000 - VKS Fab Sliders - Offroad Evolution Full Skids - Teraflex Sleeves - ARTEC Truss - EVO C Gussets - Synergy Bumpstops - JKS Control Arm Skids - Rigid 10" E-Series Light Bar and SRM Backup Lights - ARB Compressor w/ 5 Gallon Viair Tank - Offroad Evolution Half Doors
nicholsmf is offline
post #22 of 40 Old 07-17-2012, 08:24 PM
TCdawg's Avatar
My BFH is On its way as I type, I'll need to do this I guess.
Pm to you Goody
TC
TCdawg is offline
post #23 of 40 Old 07-17-2012, 09:04 PM Thread Starter
That'll do it!
post #24 of 40 Old 07-18-2012, 04:38 AM
I need to do this, I no longer need to use the skid as my edisco took a shit on me and I'll be replacing it with a stock one probably just do what nicholsmf did (no welder here). Or do you think I should leave the skid on for the hell of it?
post #25 of 40 Old 07-26-2012, 09:39 AM Thread Starter
This may work as a full scale print-out
https://www.dropbox.com/sh/pl1i07s6f...L4M/BFHfix.PDF
