GenRight Aluminum Rear Bumper Installation - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 03-19-2012, 09:49 AM Thread Starter
ADDICTION II build begins....
TXROCK's Avatar
Remove the stock bumper and clean/prep the frame surface for the new bumper:
____________________________
Mark and drill the following holes on the bumper per the instructions...follow the instructions (read everything first and line up all the tools to make installation easier and faster):
If you are going to install the trailer hitch you will need to shorten the bolts....a great tool for doing this is a dremel with a cutting wheel!
Mark and drill your holes for the bumper mounting bolts to the frame:
If you are going to run the trailer hitch, you have to notch out this plate on the bottom of the bumper. If not, you can leave this in place:
Next, wire all of your lights together ran from the drivers side over to the passenger size to tap into the passenger side tail lamp area (if you are running the lights as a backup light).
Note: The white rubber washers that come with the lights go on the backside of bumper and not on the front side of the light.
Next, put in the shackle mount bars, slip on the bumper and start bolting it all together!
U.S. Army
TXROCK is offline
post #2 of 18 Old 03-19-2012, 09:50 AM Thread Starter
TXROCK's Avatar
U.S. Army
TXROCK is offline
post #3 of 18 Old 04-04-2012, 10:27 PM
karls's Avatar
Can you tell me what your gap looks like between the top of the bumper and the body? I'm debating if I should be prepared to bedline that lip too or leave it be. And how long did it take you to install? It's obviously not a 5 minute quick bolt up.
karls is offline
post #4 of 18 Old 04-11-2012, 11:28 PM Thread Starter
TXROCK's Avatar
The gap between the body and the bumper is about 1/2". You will be fine without bedlining but is up to you. For the install, it took me a little while due to installing it at my house with my wife and 3 boys home! But discounting that, it could take you an hour or two (with cleaning/painting the crossmember prep) as long as you have the right drill bits and someone to give you a hand as you do the final bolting in.
U.S. Army
TXROCK is offline
post #5 of 18 Old 04-12-2012, 12:41 AM
Nomadr's Avatar
Here is mine raw and attached and painted. Like TX says, it is about a half inch.
It took me a while to install. The priming and painting and prep took a full day, didn't have all the proper tools, so kept having to run out, bla bla. I used DupliColor bed liner, and it seemed to like a few days to set. I would definitely do as the instructions say and fit it first, run the bolts in to make sure everything fits right, then remove and prep and paint. After painting, it is easy to scratch up if you have to remove it a couple of times when doing the final install. However, the bedliner makes it easy to touch up.
2011 Unlimited Rubicon
Currently: Henderson, CO
Nomadr is offline
post #6 of 18 Old 05-24-2013, 12:08 AM
Jonboy's Avatar
did those lights come w/ the bumper, and how bright are they?
Jonboy is offline
post #7 of 18 Old 05-24-2013, 12:48 AM Thread Starter
TXROCK's Avatar
They are very bright....was sitting in a parking spot, put the jeep in reverse and with the light bouncing off of the building across the street I thought I had a car sitting behind me on the street. Given I have a backup horn installed on the jeep and the light wasnt moving, I ended up getting out of the jeep only to realize the car keeping me from backing out was actually my Jeep! LOL
Here are the lights I have installed...there are a couple other light options available for the holes as well but are more expensive.
http://www.genright.com/ProductInfo....0#.UZ8MZ-A796E
Krawl Off-Road, Rebel Off-Road, River City Off-Road, Northridge, etc are all vendors for GR so
U.S. Army
TXROCK is offline
post #8 of 18 Old 05-24-2013, 04:59 AM
edthesniper's Avatar
Nice write up "T"
edthesniper is offline
post #9 of 18 Old 05-18-2014, 08:06 PM
rdlynch2's Avatar
I just received my GR rear bumper in the mail today!
Question, is there enough available space with the bumper installed to install the backup lights? I ask because I plan on purchasing the lights at a later date, and obviously would prefer to not have to remove the bumper. Thanks!
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #10 of 18 Old 05-18-2014, 08:25 PM
Jonboy's Avatar
Its pretty tight in there once the bumper is on. I waited till I got my lights before installing it for that reason. And I'm glad I did, I had a tough time installing it and wouldn't want to go through it again. (but love it now that its on there)
Jonboy is offline
post #11 of 18 Old 05-19-2014, 11:55 AM
rdlynch2's Avatar
Whats so hard about it?
rdlynch2 is offline
post #12 of 18 Old 05-20-2014, 01:27 AM
Jonboy's Avatar
EDIT: I had a tough time lining up the bolt holes with the tow point that sits inside the frame. Plus I swear the bumper changed a little somehow in the powercoat process as my holes lined up perfectly beforehand. Took a little force and some cursing but I finally got it on.
Jonboy is offline
post #13 of 18 Old 05-20-2014, 02:12 PM
rdlynch2's Avatar
Do you feel its necessary to fit before painting? I have yet to hear about significant fitment issues with this bumper...
rdlynch2 is offline
post #14 of 18 Old 05-20-2014, 03:13 PM
Jonboy's Avatar
I had my bumper up and down multiple times when installing it, so for me there was no question I needed to pre-fit it. I would have messed up my powdercoat had I not, for sure. But you may be a better installer than me!
Jonboy is offline
post #15 of 18 Old 05-20-2014, 07:39 PM
EMG006's Avatar
I fit mine up after powder coating it. No issues, but a helper will make lining everything up easier.
I had to pull my bumper back off to instal the lights, I have their $20 version and they are crap.
River City Offroad
Metal Cloak
EMG006 is offline
post #16 of 18 Old 05-26-2014, 10:47 AM Thread Starter
TXROCK's Avatar
If you order the LED lights for the bumper, you will need to install them and trim the backing a little before installing as there isn't enough room for the entire plastic mounting/thread surface on the backside but plenty of room for the light and securing it prior to mounting. If you trim it right everything fits fine.
As far as the lights, I have the standard 3-LED lights with mine and they work just fine. They throw enough light that from the light bouncing off the building across the residential street I though I had a car behind me that I couldn't see in the mirrors. Actually got out to look and then felt like an idiot realizing it was just me lighting everything up!
For bumper fitting/placement, it's best to line everything up first before attempting to mount, make sure you mark your "drill holes" for the bolts (if powder coating don't drill until after powder coating as the holes will change due to powder coating thickness), and then mount. It is best to have a friend help just for a second set of hands although I have installed a few of them by myself (including my own).
U.S. Army
TXROCK is offline
post #17 of 18 Old 05-28-2014, 07:19 PM
rdlynch2's Avatar
Got er installed last weekend. Kind of a bitch to get all the necessary drilled holes in the frame to line up with those on the bumper, took a lil finesse, but we got it. I decided to ditch the trailer hitch, as I never use it and prefer the look. Didn't order the backup lights when I ordered the bumper, looks like i'll have to remove it when I get em in. Either way, I like the way it came out. Rattle canned it with Rustoleum Hammered black. Comes out more of a dark textured gray than black.
[IMG][/IMG]
rdlynch2 is offline
post #18 of 18 Old 05-29-2014, 08:40 PM Thread Starter
TXROCK's Avatar
[IMG][/IMG]
looks good!
U.S. Army
TXROCK is offline
