OEM Tailgate Check Rod Retrofit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 03-02-2012, 02:40 PM Thread Starter
ronjenx's Avatar
I never liked that my '08 JK's tailgate had no provision to keep it open. Gas struts were not the answer for me, either.
When looking at a 2012, JK, I noticed it had a conventional door check on the tailgate. So, I went to the parts department and looked it up. I had one the next day.
I wouldn't call this an easy installation, at least for the first one.
1. A photo of the tailgate check rod as received from the dealer.
2. The first thing I did was make a template of the mount, including pilot holes for the mount bolts.
3. Use the template to drill the pilot holes in the body, secure in place, and scribe the opening. I looked at a 2012 and placed the template in approximately the same location on my 2008.
4. Center punch, then drill the four corners.
5. Cut out the opening, and drill the pilot holes to size. I used -20 screws/nuts to mount the plate.
6. This pic shows the reinforcement plate which I had to make for the tailgate. The OEM installation is reinforced on the inside, which cannot be accessed after the tailgate is built, (without cutting and welding).
7. Here is the check rod assembly in place. But don't close the tailgate yet...
7a. Make a cut-out in the inner panel to clear the check rod when the tailgate closes.
8. ...and here it is in service.
The check rod works very well. It only holds the tailgate open. It doesn’t serve as a travel limit. Tailgate open travel is still limited by the hinges.
ronjenx is online now
post #2 of 5 Old 03-03-2012, 07:04 PM
I like this idea a lot. Thanks for the write up, I'm going to check out my buddy's 2012 tomarrow and probably order the part monday.
Thanks Derrik
Miamoo21 is offline
post #3 of 5 Old 04-09-2012, 12:03 PM
Did you make that plate that attaches to the tailgate or did it come with the kit?
2011 JKU Rubicon
PSC Evap Skid
PSC Diff Covers
Dynomax Rock Crawler exhaust
ACE Rear Bumper and Tire Carrier
Rock Krawler 2.5 Flex W/ Bilstein 5100's
35" Nitto Trail Grappler's
G19T is offline
post #4 of 5 Old 04-09-2012, 08:59 PM
Nice, my woods setup works better for my needs. Good job.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #5 of 5 Old 04-09-2012, 09:00 PM
Very nice! What did the part cost? I wonder how it will work with the stock sub..
