Rock Hard 4x4 JK Oil Pan, Trans & Dual Cat Converter Skid Install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 02-19-2012, 08:19 PM Thread Starter
RGJK's Avatar
Today I installed my Rock Hard Oil Pan / Trans skid plate. I searched for a write up and couldn't find one, so I wanted to write my own for others to use.
This is on a 2008 JK Unlimited Sahara.
Here we go....
This is what comes in the kit:
Here's what's in the bag of bolts:
This is the passenger side mounting arm. This is the first thing to install.
You will use the front hole below the motor mount. It is the one that is elongated.
Here's the passenger side mount installed. Be sure to leave this loose for now. No washers came with the kit, so I just found some for the bolt head.
Here is the driver side mounting arm. The shorter length of the arm will mount to the motor mount.
Getting the bolt in the slotted hole can be tricky. This is the only angle that I was able to make work. There wasn't enough room to use a washer on this side.
Here is an installed pic of the driver side mounting arm.
NOTE: I did not have a auto trans skid. If you do, remove it now. Also remove the Transfer case skid at this time. You will re-install it at the end.
Now install the driver side catalytic converter skid.
Now bolt up the front edge of the skid to the 2 mounting arms. I did this by myself, so I was laying on a creeper with the plate on top of me. I lifted up the front, hand tightened the bolts and then secured 1 bolt in on the rear of the plate.
2008 Rescue Green JKU Sahara
RGJK is offline
post #2 of 19 Old 02-19-2012, 08:19 PM Thread Starter
RGJK's Avatar
Next, connect the catalytic converter skid to the main skid. You will use the 2 button head bolts for this. If you install them in the shown manner it will be easier to snug them up.
This is the supplied spacer that drops the skid below the exhaust pipe cross over.
It installed between the skid and the crossmember.
Now you can start to tighten everything back up. I wanted to re-use my stock transfer case skid so used the original bolts to re-install it. I used the provided bolts on the other two holes.
After everything was tight I took it for a test drive and i noticed a slight rattle. This was due to the exhaust contacting the skid on the far driver side. To fix this I just loosened the bolts and put 2 washers on the far driver side bolt. Problem fixed.
Thats all there is to it. This skid seems very solid.
Enjoy!!
Dom
RGJK is offline
post #3 of 19 Old 02-20-2012, 06:00 AM
DaK
Very nicely documented... that rockhard stuff is good stuff right there. You will be happy you bought it when it comes time to use it.
DaK is offline
post #4 of 19 Old 02-23-2012, 12:35 AM
Berserker's Avatar
Originally Posted by RGJK View Post
When I installed mine I cut off the little "wings" that protect the stock bolts on the transfer skid so the supplied bolt head sliders would fit.
After a few hard hits my skid dented and my exhaust cross-pipe would rattle against it. A combination of spacers (washers) on the crossmember bolts (between the crossmember and the spacer plate) and a few more rock hits to get it touching the exhaust fixed the problem.
Damn the cannons, full speed ahead! |
Berserker is offline
post #5 of 19 Old 02-23-2012, 04:59 PM
Ipe
Ipe's Avatar
Maybe this is an optical illusion but something seems to be missing here. Looks like the bolt head is missing from your upper control arm at the dif
Great write up on the skid system. I'm officially jealous.
Ipe is offline
post #6 of 19 Old 02-24-2012, 07:04 PM Thread Starter
RGJK's Avatar
Holy cow! It does sort of look like that. I just went and checked to be sure. The nut is there and everything is secure
RGJK is offline
post #7 of 19 Old 02-25-2012, 09:48 AM
Ipe
Ipe's Avatar
I see the nut, is there a head on the bolt still?
I'm glad its just an optical illusion. That could have brought the suck.
Ipe is offline
post #8 of 19 Old 03-24-2012, 03:44 PM
Thanks for the write up , i just picked mine up and ill probably tackle it tomorrow morning. how long did it take you?
JustTryingtoLive is offline
post #9 of 19 Old 03-25-2012, 05:58 AM Thread Starter
RGJK's Avatar
You're welcome.
It took about three hours including the test drive and re-shimming of plate.
Have fun!
RGJK is offline
post #10 of 19 Old 03-25-2012, 05:47 PM
what size shims did you use?
post #11 of 19 Old 03-25-2012, 05:54 PM Thread Starter
RGJK's Avatar
In addition to the spacer plate that came with the kit, I used 2 grade 8 washers. They are about 3/16 of an inch think each.
RGJK is offline
post #12 of 19 Old 03-25-2012, 07:25 PM Thread Starter
RGJK's Avatar
EDIT: the washers are a total of 3/16 thick.
RGJK is offline
post #13 of 19 Old 04-03-2012, 01:04 PM
TJDukit's Avatar
Just got mine delivered and installed today. It only took me about 45 minutes to get it all buttoned up. Luckily I had already found this write up because my skid only came with half the directions. I ended up cutting the ears off my t-case skid so I could use the bolts and bolt skids that came with it.
Thanks for the awesome write up.
'09 JKUR. Metal Cloak overlines, TF 3" LA, 35" Nitto Trail Grapplers, Home built winch bumper, custom built sliders, RK Drag Link and HD Pro Tie rod, Adams front shaft, TF Big Brakes, Speed Bumps, Warn M8000
I.Y.A.A.Y.A.S.
TJDukit is offline
post #14 of 19 Old 10-10-2013, 08:40 AM
Any chance of getting the photos back online ? I'd love to read this writeup with the photos to help me understand thinks like "This is what comes in the kit"
Here we go....
Supercazzola is offline
post #15 of 19 Old 11-10-2013, 06:15 PM
I second this. Please show the pictures. I thought I was a fairly smart guy, but while my wife and I are installing this we are running into some issues. One guy said 45 mins to install this. HOLY smokes, I've been at this for hours, probably more than 2 and still aren't even close to getting oil skid up??? Any help would be great. Oh and where does this crazy spacer looking guy go??
OllllO Fanatic is offline
post #16 of 19 Old 11-13-2013, 01:06 PM
J1000's Avatar
Mine isn't a 2013, but here's a video I made of my install. I did get the one bolt skid to lay flat after I was done as well. I had to loosen the two rear bolts on the t-case skid to let it move laterally.
Installing the Rockhard 4X4 engine oil pan skid - YouTube
J1000 is offline
post #17 of 19 Old 12-17-2013, 01:44 PM
Subscribed!
I have the other 2 skids from Rock Hard parts, and a rear heavy-duty cross-member from Clayton - my original one was almost destroyed..
I am planning on installing this oil/ trans, but recently started having a problem with vibrations... anyone experiencing this problem? If so, how did you solved it? I have a feeling this vibrations comes from the exhaust system, when I press the throttle...
Any insights would be much appreciated!
Rubina is offline
post #18 of 19 Old 12-28-2013, 11:47 AM
J1000's Avatar
Originally Posted by Rubina View Post
Subscribed!
Yes, the vibration it adds is maddening; it hides other things that could be going wrong. My first attempt to reduce/dampen it was to take a long strip of rubber (actually a garage door bottom seal) and cut it to fit along the back edge of the skid with holes cut for the bolts, and rubber washes on both sides of the front arm mounts. It helped a little, but it is still noticable..
J1000 is offline
post #19 of 19 Old 02-10-2014, 07:58 PM
sorry it took so long to get back...
I have found that the exhaust was vibrating agains one of the heat shields and that caused it. a quick fix in the exhaust hanger and so far...
I could not install anything else to create space, because of the HD cross-member. It leaves no room for further washers or even the shim plate.
If it starts doing it again, I will look into the same place again and next I will use a metal clamp - have seem this in another forum and it might work.
BTW, I can't seem any of the pics in the first post. Am I the only one?
Rubina is offline
