New LED Panel Rocker Switches - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 02-15-2012, 09:07 PM Thread Starter
I just got my new OTRATTW Rocker Panel Switches Installed. Very easy installation.
1 Hot wire to battery/Fuse Box
1 Ground Wire
1 wire to lights or wthatever the rocker will turn on
1 wire tapped into Dash Lights
I did have to shave the switches a little bit. They fit perfect into the panel, but the actual rocker has a slight arch to it, which rub against each other. Simple solution. I just put them on a belt sander for a few seconds & they were perfect. Here are pictures of them with lights on. They are green when the dash lights are on, & turn red on the bottom when the rocker is turned on.
JKU2007 is offline
post #2 of 18 Old 02-15-2012, 09:16 PM
jeeperak's Avatar
i like those a lot
jeeperak is offline
post #3 of 18 Old 02-15-2012, 09:17 PM
Those look nice, a picture not 3" away from them would kinda be nice. I wonder if they clear a manual shifter.
post #4 of 18 Old 02-15-2012, 09:38 PM Thread Starter
No problem clearing a manual shifter.
JKU2007 is offline
post #5 of 18 Old 02-15-2012, 09:56 PM
VKS Fab
JK Vick's Avatar
Im thinking he ment the manual 6speed... you know, clutch and shit
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #6 of 18 Old 02-15-2012, 10:13 PM Thread Starter
Thanks, but:
1) If you read right above the photos it says "No problem clearing a manual shifter." So I know he meant a manual (6 Speed)
2)He asked for pictures that were not 3" away so I took some further shots.
Thanks again...
JKU2007 is offline
post #7 of 18 Old 02-15-2012, 10:18 PM
VKS Fab
JK Vick's Avatar
With the 6spd the shift boot will hit the switches (normal rockers), not the shifter itself. I believe that's what goody was getting at. What switch panel are you running, daystar?
JK Vick is offline
post #8 of 18 Old 02-16-2012, 08:30 AM Thread Starter
yes, daystar switch panel
JKU2007 is offline
post #9 of 18 Old 02-16-2012, 10:54 AM
I am thinking about getting some of these for my sPod. I would want to tie them into the dash lights though. Any more info in where you tapeed in so I can see how difficult it would be to add this to the sPod.
Jon
08 Rubicon
JeepinJon is offline
post #10 of 18 Old 02-16-2012, 01:53 PM
PO'BOY's Avatar
where did you get the zombie one? i think that is pretty badass.
PO'BOY is offline
post #11 of 18 Old 02-16-2012, 01:58 PM
azrwilkinson's Avatar
Nice setup. What wattage is better for Zombies? Also do they shy away from LED lighting more than halogen? Thanks
OR-Fab tire/can carrier, OR-Fab hooped stubby bumper.
TrailMaster Stealth Long Arm 4.5 inch (BAD ASS LIFT)
35 BFG KM2 on BlackRock D windows
azrwilkinson is offline
post #12 of 18 Old 02-16-2012, 03:26 PM
Gotlime?'s Avatar
x2 This please
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline
post #13 of 18 Old 02-16-2012, 05:29 PM
07unlimitedx's Avatar
Nice. I need to add some more switches. Looks like a good alternative. I already have an S pod
07unlimitedx is offline
post #14 of 18 Old 02-16-2012, 05:52 PM
Ah, then that will not clear the boot of a manual. Same panel I have, can only run one switch in it.
post #15 of 18 Old 02-16-2012, 09:42 PM Thread Starter
Very simple. Pull the dash panel off. Behind the panel going to the HVAC is a small bundle of wires. I just tapped into the orange w/ grey striped. Took 5 minutes.
JKU2007 is offline
post #16 of 18 Old 02-16-2012, 09:44 PM Thread Starter
otrattw is the name of the company. Search on google. They have an online site
JKU2007 is offline
post #17 of 18 Old 02-16-2012, 09:48 PM Thread Starter
x2 This please
Orange wire with a grey stripe behind the dash panel connected to the HVAC
JKU2007 is offline
post #18 of 18 Old 02-16-2012, 09:50 PM Thread Starter
You can use these switches for LED or Halogen offroad lights with no problems. the lights inside the switch are LED.
JKU2007 is offline
