Spare Tire Delete with License Plate Relocation and LED Brake/License Plate Light - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 02-15-2012, 08:48 PM Thread Starter
Ryan L's Avatar
Cool Spare Tire Delete with License Plate Relocation and LED Brake/License Plate Light
What are we doing?
Removing spare tire, relocating license plate to cover tail gate opening, legalizing it with license plate light and brake light, and 'cleaning up' the voids with painted plugs.
Why?
I wanted to clean up the look of my rear while dropping 130 lbs of weight. My goal was to make this completely reversible so the spare tire can be thrown back on at any time.
So where is your spare tire?
That's not what this thread is about.
What do I need to buy?
(about $100 worth of parts)
ORO LitePLATE - License Plate Light and Third Brake Light - $40
MOPAR License Plate Delete Plug - $16
Front License Plate Bracket (Napa) - Part Number 'BK 7302450' - $12
License Plate 'Snap-in' Fasteners with Screws - $8
MOPAR Touch Up Spray Paint - $11
Plastic/Nylon Hole Plugs (Napa) - $10
Rubber Weather Stripping (Home Depot) - $10
Spring Toggle Bolts w/ Washers (Home Depot) - $10
Flat Metal Bracket with Holes (Home Depot) - $5
How did you go about it?
I'm not going to go over every step, but I'll summarize with a few notes and pics...
Spray paint license plate plug and plastic hole plugs with body matching touch up paint (several coats, let dry between coats).
Remove spare tire, spare tire mount, third brake light (unplug connector, don't cut), air vent, and license plate w/ holder. You will need to remove both brake lights in order to access the license plate holder and ORO LitePLATE power connections.
Prepare license plate mount: Snap in plastic fasteners into plate mount, cut/bend pre-drilled metal bracket just long enough to fit vertically in tailgate opening, attach metal brackets to license plate mount with toggle bolts. Cut and attach weather stripping to top and sides of the license plate mount's back side. This will keep moisture out of the tailgate opening while letting the interior breathe through the bottom portion of the license plate mount.
Fish ORO LitePLATE wiring from tailgate opening through the hole that leads to the interior side of the tail gate. Route wiring behind plastic cover and through the cloth sheath near the tail gate hinge.
With the LitePLATE loosely hanging, start to install the license plate mount by inserting the metal brackets inside the tailgate opening. The bolts should be just loose enough to be able to fit the metal brackets without scratching/hitting the tailgate opening itself.
Once the two metal brackets are inside, start tightening the toggle bolts.
Once everything is lined up, finish tightening the plate mount. (In this pic, I've already installed the painted plastic plugs to fill the spare tire mount bolt holes.)
Now slide in your license plate and secure the plate with screws. This also secures the LitePLATE.
Now it's time to wire in the LitePLATE. Pull up the passenger side carpet right behind the tail light. Remove rubber wiring harness plug leading to the fender in order to gain better access to the wiring. Two of the LitePLATE connections (brake light power and ground) can be spliced in at the tail light wiring harness (harness pictures on the left).
LitePLATE black + tail light black
LitePLATE green + tail light white w/ purple stripe
The third connection (license plate light) is taken at the harness that routes through the tailgate (pictured on the right side).
LitePLATE red + tail light white w/ a gray stripe (other years may different, such as white w/ brown stripe, in some cases).
Tuck away wiring, reinstall carpet, reinstall the tail lights, install painted license plate delete plug along with all other painted plastic plugs, ensure license plate light and brake light work, ???, profit.
2010 Surf Blue Unlimited - Beach Duty
Ryan L is offline
post #2 of 26 Old 02-16-2012, 05:29 AM
Fklein6768's Avatar
Nice work- looks good!
Is this thing on?.....
www.4x4s-pod.com
Fklein6768 is offline
post #3 of 26 Old 02-16-2012, 08:52 AM
PO'BOY's Avatar
looks good. i need to do that soon as the weather breaks.
PO'BOY is offline
post #4 of 26 Old 02-17-2012, 07:00 PM
Canadian Bear's Avatar
That is nice and clean. Good work
2011 CANADIAN BEAR JK
/l ,[__
l----L-OlllllllO-
()_) ()_)-o-)_)
Canadian Bear is offline
post #5 of 26 Old 02-22-2012, 07:56 PM
sringer's Avatar
What year is your jeep? I have an 07 and I am installing this next week
I am here: http://maps.google.com/maps?ll=48.426887,-114.347032
Sent from me to you, using my iPhone
2007 Rescue Green Wrangler x 2 dr
Bushwacker Rear corners
Rugged Ridge Billet Grille-black
Deep tinted front windows and top
no more wrangler x decal- only project jk decal
neon blue led dome light
neon blue led strip in footwel
kmc xd addict matte black 17x9 -12 mm offset
bfg km2 35x12.50x17
Rugged Ridge Hinge overlay-black
magnaflow exhaust setup
3rd brake light w/ tramp stamp
soon to come..
bumpers and armor
sringer is offline
post #6 of 26 Old 02-22-2012, 08:19 PM
JKashat's Avatar
Looks great. Nice idea. One observation though... It's a bit off center (to the right). Was this intentional, necessary, or just an oversight?
2012 JKUR Bright White - Ordered 2-1-2012, Built 3-7-2012, Arrived 3-9-2012, Picked Up 3-10-12
JKashat is offline
post #7 of 26 Old 05-30-2012, 06:49 PM Thread Starter
Ryan L's Avatar
I ended up centering it after I noticed it in the pics.
Ryan L is offline
post #8 of 26 Old 05-31-2012, 05:21 PM
damon.l's Avatar
good job... looks very nice!
damon.l is offline
post #9 of 26 Old 05-31-2012, 08:28 PM
Good Job.
post #10 of 26 Old 05-31-2012, 09:21 PM
JKrazed's Avatar
Feedback: 13 reviews
The vent opening is not the same in the '07s. The opening is vertical.
PROUD to be an
JKrazed is offline
post #11 of 26 Old 05-31-2012, 09:47 PM
md_rubi's Avatar
I'm stealing this idea till my tailgate gets done! Thanks
md_rubi is offline
post #12 of 26 Old 06-02-2012, 12:03 AM
07XMan2Door's Avatar
Looks great. Was it hard fishing the brake light wires into the vent area?
Pics of my Jeep....
07 2 Door Red Rocker, 6 speed, AFE intake, 2.5 Terraflex plus 1", 5.13's, rear locked, 35" Cooper STT's on 15" Ions, EVO Sleeves & Gussets, DIY Bumpers & stuff.
07XMan2Door is offline
post #13 of 26 Old 08-25-2012, 05:13 PM
Thisguyhasadd42's Avatar
ok i just used this, and the plate light works but the brake light doesnt. You got any ideas? TIA
Thisguyhasadd42 is offline
post #14 of 26 Old 01-30-2013, 08:26 AM
SuffolkSam's Avatar
That's sick. Planning on doing this or something along the lines as this. DO you know if that 3rd brake light DOT approved or whatever? Like meaning any legal issues?
SuffolkSam is offline
post #15 of 26 Old 02-13-2013, 12:41 AM
DeucesALLin's Avatar
FWIW...
... OEM 3rd lights arnt stamped DOT.
Soon to be a vendor!!!
Looking for a good Rat Rod JK donor vehicle.
DeucesALLin is offline
post #16 of 26 Old 06-25-2013, 06:54 PM
Nice clean work!
I didn't relocate the licence plate but did delete the spare tire for city driving and fabricated my own cover. I have a compressor and tire plug kit on board if I get a flat, but I always throw the spare in the back when off-roading or on long trips. I just ratchet strap it down to heavier tie downs i installed in place of the stock ones in the back.
I like not having the spare tire on the tailgate. The "Jeep Purest" may frown on this but it creates less of a blind spot and I like the looks of the back without it.
FirstJeep is offline
post #17 of 26 Old 07-20-2013, 08:39 AM
Originally Posted by FirstJeep View Post
Nice clean work!
What did you use to plug where the 3rd brake light wiring comes out through
The tailgate?
MomTank is offline
post #18 of 26 Old 08-20-2013, 10:41 AM
JimVZ's Avatar
My Relocation
This is how mine came out
2018 JL Sahara on order!
JimVZ is offline
post #19 of 26 Old 08-20-2013, 12:50 PM
CDA
This is pretty cool idea, but why would you want to remove your spare tire? Besides saving roughly 130lbs, is that really making a difference?
Just curious...
CDA is offline
post #20 of 26 Old 08-20-2013, 02:08 PM
Nice job looks really clean I did something similar to mine except I used the vector off road back plate and mounted two spot lights as well. Name:  ImageUploadedByAG Free1377029314.868218.jpg
Mcdowell11290 is offline
post #21 of 26 Old 08-20-2013, 04:18 PM
JimVZ's Avatar
Just curious...
Yeah, it really increased my gas mileage. I average 20mpg to 21mpg
JimVZ is offline
post #22 of 26 Old 08-20-2013, 04:20 PM
JimVZ's Avatar
Plus it makes things look more centered, and I can center my back up camera as well.
JimVZ is offline
post #23 of 26 Old 10-25-2013, 08:25 AM
Just curious...
It is nice to be able to see out of your rear window, to keep the COG low, and to have one $500+ object easily removable or vandalizable... is that a word?
post #24 of 26 Old 01-25-2014, 09:21 PM
Can anyone tell me where I can get this plate? Like the clean non etched/design look.
carguyohio is offline
post #25 of 26 Old 01-27-2014, 12:24 PM
jkx0778's Avatar
Here you go: https://www.jkowners.com/forum/showthread.php?t=87867
________________
jkx0778 is offline
