Axle Seal Leak - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 02-02-2012, 02:16 PM Thread Starter
Muddevil's Avatar
Question Axle Seal Leak
I'm looking at changing my front axle seals because they are leaking. Anyone done this before? Do I need a press or speciality tools to accomplish this?
Orlando
09 Black JKUR
Muddevil is offline
post #2 of 8 Old 02-02-2012, 02:53 PM
Fklein6768's Avatar
Orlando
There are a couple threads that show how to make a homemade "press". Not hard just pay attention to what ur doing.
Sent from my MB860 using Tapatalk
www.4x4s-pod.com
Fklein6768 is offline
post #3 of 8 Old 02-02-2012, 09:38 PM
Every aspects maintain a broad perspective so we will determine a broad vision so be conscious in all matters and get a remarkable accomplish so be happy for best resources and get a clear vision for best .
Orten Frank is offline
post #4 of 8 Old 02-03-2012, 05:38 AM
Fklein6768's Avatar
I fancy myself as a pretty smart guy but I have no idea what the hell u are trying to say
www.4x4s-pod.com
post #5 of 8 Old 02-03-2012, 11:18 AM
Jaybee1669's Avatar
It's hard to tell if it's good old fashioned frontier jibberish or just really Zen.
Jaybee1669 is offline
post #6 of 8 Old 02-03-2012, 05:01 PM
venom's Avatar
anyway,
changing front axle seals is a pain but not that tricky
special tools = 36mm socket and a seal driver
Pull the drain plug on the side of the diff and drain the lube
pull the wheels
have someone hold the brakes and break the 36mm axle bolt loose and remove it
pull the brake caliper/brackets - 2x 21mm bolts
rotors slide off
5mm allen bolt to get the speed sensor out (not completely needed but makes life easier)
3x 13mm 12 point bolts takes the unit bearing off - brake dust shield will come with it - turn the axle shafts to get room for the bolts to come out past the u-joints
axle shaft will slide out
repeat on the other side
pull the diff cover - let it pee more grease for awhile
if you have a rubi - look behind the diff on the top right side in the back and locate the little mushroom shaped plunger that rides on the locker ring to tell it if its locked or unlocked - just remember its there and dont mangle it when you're wrestling with the diff.
also if you have a rubi - theres an 8mm bolt on top of the axle housing to remove the locker plug, then you can pull the slack wire out the hole and unplug the locker from the back of the plug- its a bitch of a plug but it does come apart.
2 bolts on either side for the bearing caps
lay all of your diff parts out in order so you put them back just like they came out.
after you pull the caps (note left cap and right cap- you can even mark them with a sharpie if you think you might F it up) then its time to pull the diff.
Some slide out, some need persuasion with a small pry bar.
Just take your time and pull it straight out - there will be spacers on either side and bearings/races that will come with it - make sure and keep them in order!
you need to put it all back in the way it came out.
the diff is pretty heavy and dropping it is a bad idea.
good time to hose it all out with brake clean or something so you can see whats going on.
after thats all out of the way you can FINALLY get to the seals.
seals themselves are in the inboard end of the axle tubes
use a broom handle, long pipe, etc from the end of the axle to pop them out towards the center.
you may also have some plastic spacers come out too - these go on your axle shafts when you slide them in to keep them centered.
shine a flashlight down the tubes and make sure you get all the spacers out of both sides
using a seal driver - carefully drive the new seals STRAIGHT into the axle tubes.
Make sure the go all the way into the tubes and go in straight.
then put it all back together the way it came out.
a few reassembly tips..
make sure you get the spacers right on the diff when you put it back in, watch the plunger.
put the plastic spacers on the axle shafts - space them out along the length of the shaft to keep it centered when you slide it in.
put some grease on the tips of the axle splines so they go through the new seals without damaging them.
I did this from memory but it should be pretty accurate.
Originally Posted by My Wife
venom is offline
post #7 of 8 Old 02-03-2012, 10:37 PM
Yep, you got it Venom. I just did it last weekend.
Although, you can leave the hubs attached to the axles. Take them out as a unit. Skips the whole partner and 36mm socket part.
geargrinder is offline
post #8 of 8 Old 02-07-2012, 11:55 AM Thread Starter
Muddevil's Avatar
Originally Posted by venom View Post
anyway,
pull the wheels
rotors slide off
Venom,
Thanks for taking the time for posting this. It doesn't sound complicated, but I usually like to see someone do it first. I retain more info that way. I will use your post as a reference.
Orlando
09 Black JKUR
Muddevil is offline
