Poison Spyder BFH w/Comp Stinger - Total Length - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 01-23-2012, 02:39 PM Thread Starter
I've had a few questions regarding the actual dimensions of the Poison Spyder BFH Comp Stinger since I've owned it. The dimensions on the site are based off the bumper itself, which can leave some grey-area regarding the actual size of it if you don't have one sitting in front of you.
In response I've taken a couple measurements so that one (probably with another set of hands) could replicate on their Jeep exactly where the nose of the stinger will end up.
Hooking a tape measure to the strap loop on the hood it's total length is going to be 53" out. Now to get the actual location you'll need another measurement to make that triangle, more or less...Measuring from the tape touching the GRILLE in the hood gap, going up 4-1/2" will locate the 1st tape measure to the angle it needs to be at.
The angle finder is just placed where there is a body line on the hood, and may be easier for a one-man measurement to be performed. That is 3 and~7/16" up from the body line (where the top of the tape is, not the bottom/concave portion).
Hope it helps someone out.
post #2 of 3 Old 01-23-2012, 02:44 PM
not as bad as i thought it was going to be! awesome info and write up!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42 MTR's
17" Spyderlock Beadlocks
post #3 of 3 Old 01-23-2012, 08:29 PM
Thank you very much Goody. Exactly what i needed.
3.5" Rock Krawler Mid-Arm Flex, Bilstein 5100s, Smittybuilt XRC Rear Bumper & Tire Carrier, AEV ProCal, 37" Nitto TrailGrappler MTs, MB 72s, 5.38s, C Gussets
RoachJeep is offline
