Rear Pinch Weld trim - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 12-11-2011, 10:17 AM Thread Starter
I looked all over last night and could not find a really good thread that showed pics of this.
I have a 6" long arm Teraflex lift with 37" tires. I have swapped out the stock dana 44's for Dana 60's and thought I would tackle this today.
Check out my build thread for more info on my jeep! https://www.jkowners.com/forum/showthread.php?t=62575
I have the Poison Spyder rear fenders and wanted to continue the line they cary for a nice finish.
njnelson is offline
post #2 of 15 Old 12-11-2011, 10:19 AM
TCdawg's Avatar
try this thread:
https://www.jkowners.com/forum/showthread.php?p=704729
TC
TCdawg is offline
post #3 of 15 Old 12-11-2011, 10:22 AM Thread Starter
Marking the cutting area
I marked the cutting area with a marker and then cut it with a sawzall. Took a grinder to it and evened everything out and rounded the edges.
njnelson is offline
post #4 of 15 Old 12-11-2011, 10:29 AM Thread Starter
Originally Posted by TCdawg View Post
Yeah, saw that one. IMO it looked liked hammered a**. Wanted to find one with measurements and a cleaner look.
njnelson is offline
post #5 of 15 Old 12-11-2011, 10:41 AM Thread Starter
Sanded everything down with 100 grit to knock the burrs off and then wiped the area with a cleaning solevent.
Masked the area off for painting and applied Quick Steel to fill the hole.
Yes, I know the grinder got away from me a little. By the time I am done sanding and painting it will all be good again!
njnelson is offline
post #6 of 15 Old 12-11-2011, 05:31 PM Thread Starter
Final pics
Sanded everything down with 100 grit and got the Quick Steel shaped. Went up to 400 grit all over and applied 3 coats of paint. Let me know what you think!
njnelson is offline
post #7 of 15 Old 12-11-2011, 07:05 PM
bnb2010's Avatar
Looks good!!
B.
bnb2010 is offline
post #8 of 15 Old 12-12-2011, 12:33 AM
Hellofa good job you did there !
Rob's-07JUNK is offline
post #9 of 15 Old 12-12-2011, 01:47 PM
Thisguyhasadd42's Avatar
this looks great!
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #10 of 15 Old 03-04-2012, 12:15 AM
Wow, very creative idea. That's the best trim job I've seen.
post #11 of 15 Old 03-04-2012, 12:33 AM
ADDICTION II build begins....
TXROCK's Avatar
^^x2!
U.S. Army
TXROCK is offline
post #12 of 15 Old 03-16-2012, 12:03 AM
Heavy D's Avatar
x3
I was going to trim my pinch seems also and I think that I just found the way that I am going to do it. Great job!
Ron
Heavy D is offline
post #13 of 15 Old 03-16-2012, 05:39 AM
Fklein6768's Avatar
Very clean looking
Sent from my MB860 using Tapatalk
www.4x4s-pod.com
Fklein6768 is online now
post #14 of 15 Old 03-22-2012, 01:58 PM
ScaleJK4x4's Avatar
Great job on the pinch weld trim!
Is there any other good way to seal a cut pinch seam/ pinch weld? Or is the Quick Steel the best way to go? Just asking, as I have never worked with it. Is it just apply, mold, set, grind, sand? And then prep/paint as any other bare metal?
-Scott S.-
'07 2Dr Silver Rubicon
ScaleJK4x4 is offline
post #15 of 15 Old 04-11-2013, 05:20 AM
Wondering the same thing. Also figured I would rtv the hole before using the quick steel.
mitter is offline
