Driver's side steering stabilizer mount - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 11-14-2011, 05:21 PM Thread Starter
I ran into a hiccup with the aftermarket drag link I am running, it's intention is to be run on a drag-link flip setup more-so than stock. It caused interference with any off the shelf stabilizer relocation bracket and it was suggested the factory location for the stabilizer should be used.
Not quite content with that I drew up a little mount in autocad and whipped a mount up with my limited skills to run the stabilizer on the driver's side.
It's more or less like this, the changes were with the supporting "gusset", it was a rough drawing and definitely needed fine tuning before burning it in. Ended up running a .4375" hole for the stabilizer, the notch for the spring mount is more like .750" deep as well.
It's 3/16" plate, clears the tie rod by plenty throughout it's sweep. Trail tested it the other night and my novice welding seems to do fine (doesn't take much for a stabilizer mount). Whats funny is I have never actually hit the factory stabilizer mount tabs until I went out two days ago. They're mangled now!
Excuse the mud
And yes my sway bar links are a tad too short, don't bind...but I'll be working on that.
It's just something a little different, if anyone is having clearance problems with the passenger's side mounts.
post #2 of 14 Old 11-14-2011, 08:26 PM
toymaster's Avatar
Do you mind posting a pic of the problem area on the passenger side.
I do not see any problem at all with what you did. I'm just curious.
JK 2dr rubi
toymaster is offline
post #3 of 14 Old 11-14-2011, 08:56 PM
Painkiller's Avatar
Great idea !!! thanks for posting this up, i have the same problem and it got even worse when I did the SS shock relocation mount ... thanks again
2010 Unlimited
RIVER CITY OFFROAD
GREEN COUNTRY OFFROAD
DNA Fabrication
Painkiller is offline
post #4 of 14 Old 11-14-2011, 09:06 PM Thread Starter
I don't have any pics exactly at the moment. But basically the drag link is straight off the knuckle, where-as the stock has a bend in it. It'll work just fine with a drag-link flip, but gets in the way when it is not.
No problemo, the intention was to maybe spark some different ways to work with it if need be. I have a CAD version of the actual mount that will print in 1:1 scale if you need it. The "gusset" isn't worth using in the drawing.
post #5 of 14 Old 03-23-2012, 01:35 PM Thread Starter
Clearer pic.
It's been on and wheeled a few times since November. No troubles!
post #6 of 14 Old 06-30-2012, 02:05 PM
Looks good.! what is the thickness of the plate..? i was considering this idea on a right hand drive jeep i am working on...
Randy James is offline
post #7 of 14 Old 06-30-2012, 02:34 PM Thread Starter
3/16" plate. The actual dimensions will be a little different and the placement of the tube, depending on the tie rod it has on it. I've run this on mine and did another one for someone else..so far so good.
post #8 of 14 Old 08-06-2012, 12:42 PM
rdlynch2's Avatar
Finally was able to take care of this today. Drove over to a friends house who has an old millermatic and burned er on.....
Clearance is fine. I didnt think I was going to be able to do it with the stock tie rod due to the adjusting collar clamp being in the way when turned full lock passenger, so I pulled it off, reoriented it in the forward position and pressed it back together with a channel lock.
Not the prettiest welds, but it will do
[IMG][/IMG]
Thanks for the write up
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #9 of 14 Old 08-06-2012, 12:45 PM Thread Starter
Cool, may want to flip the bolt the other way for a little more clearance.
post #10 of 14 Old 08-06-2012, 12:58 PM
Rottenbelly's Avatar
Beat me too it!!
You smell that?
Rottenbelly is offline
post #11 of 14 Old 08-12-2012, 03:45 PM
rdlynch2's Avatar
Goody
Did you notice your rig pushing to the right following the relocation of the SS to the driver side?
Whenever I put mine on (driver side), my rig pushes right. But when I have it mounted in the traditional location, it drives fine.
Im thinking of adding a little cross caster to the passenger side to counter it but I wanted to see if you experienced what I am as well. Thanks..
rdlynch2 is offline
post #12 of 14 Old 08-12-2012, 04:41 PM Thread Starter
Originally Posted by rdlynch2 View Post
Goody
No, the SS mount isn't going to cause any sort of push or pull. You do have a Bilstein SS, which has the reputation for causing pulls by itself, due to being charged.
post #13 of 14 Old 08-12-2012, 05:27 PM
rdlynch2's Avatar
Yeah for sure. Makes sense that if its mounted on the passenger side it would push left, driver side, push right
rdlynch2 is offline
post #14 of 14 Old 08-13-2012, 07:58 AM
nvrdun's Avatar
I may have to do this, it is just so crowded over there on the passenger side!
nvrdun is offline
