Homebrew rock sliders - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 11-07-2011, 06:15 PM Thread Starter
Decided to build some new rock sliders that would provide some more rocker protection and tie into the frame so I would stop bending my tub.
Started with some square plates and welded some nuts on the back side.
I mounted those plates to the frame
Sorry about the dark cell pics
Used some 2x3 rectangle tubing to tie the rail into the frame. Welded a plate to the rectangle and bolted it to the one that was on the frame.
Used some 1 1/2 dom tubing to make the slider. After I got the straight rail tacked in then I just bent some tube for the upper part, put in some spacers for added strength and extra rocker protection and welded everything up.
HOT_DAMN is offline
post #2 of 8 Old 11-07-2011, 06:18 PM Thread Starter
HOT_DAMN is offline
post #3 of 8 Old 11-07-2011, 06:43 PM
JKO Dickhead
Asmmns's Avatar
Nice !!
__________________
CURE SMA !
Asmmns is offline
post #4 of 8 Old 11-07-2011, 11:25 PM
SCOUT37JK's Avatar
why bolt them? why not just weld right to the frame?
homebuilt JK - blood, sweat, lemonade. renamed LOOSE NUTS
SCOUT37JK is offline
post #5 of 8 Old 11-08-2011, 06:56 PM Thread Starter
I thought about it but wanted to be able to remove them without having to cut on it. Trust me I was very close to welding them on, would have made things much easier.
HOT_DAMN is offline
post #6 of 8 Old 11-08-2011, 07:09 PM
I like it.
4x4x4 is offline
post #7 of 8 Old 11-09-2011, 08:43 PM
SCOUT37JK's Avatar
they do look good.
post #8 of 8 Old 11-10-2011, 12:05 AM
reddragons's Avatar
Those look good and cover the sides well,
I bent and welded tubing to my stock rubicon rockers, they work well, but they aren't as stiff as I would like. I'm going to do this soon.
reddragons is offline
